Author Topic: Velocity stacks on N/A manifold?  (Read 1970 times)
November 08, 2009, 06:41:31 am
Vanagoner
  • 219
« on: November 08, 2009, 06:41:31 am »
I've already changed the air filter/intake setup on my vanagon; removed the stock panel filter and ducted the intake to a cotton cone filter (3") in a closed box inside of the left air scoop column.  An excellent seat of the pants difference for me in overall power.  I'm wondering if anyone has added velocity stacks to their n/a idi intake, and if it helped at all?  The vanagon intake runners are shorter than the normal ones, and now that my panel filter is out I could add some tuned length.  Your thoughts (besides get a turbo)?
Sage
Reply #1November 08, 2009, 08:38:57 am
GEE-BEE
  • 1604
Re: Velocity stacks on N/A manifold?
« Reply #1 on: November 08, 2009, 08:38:57 am »
IY INTAKE HAS LONG RUNNERS
I HAVE FOR 100.00 IF YOU WANT IT , IT WAS PROFESSIONALLY CLEANED
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
