Author Topic: What's the worst fuel milage you can get??  (Read 135832 times)
November 01, 2009, 07:01:51 pm
maxfax
  • 2126
« on: November 01, 2009, 07:01:51 pm »
I though I'd try something different..   It's always asked "How good of milage do you get", now let's see the other side..   Fuel leaks and mechanical failures don't count..   :P    I'm talking about crazy mods and heavy feet...   ;D
My personal worst was about 34mpg in an 81 N/A 5 speed with the governor mod....
Reply #1November 02, 2009, 03:54:42 am
catlin_cava
  • 1954
Re: What's the worst fuel milage you can get??
« Reply #1 on: November 02, 2009, 03:54:42 am »
17 MPG. 1.9 with GTI transmission in a MK3. Straight pipe Exhaust.....Actually that was my Average MPG with that car ::)
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #2November 03, 2009, 11:26:32 pm
  • 3468
    • McScrubbins Body Wash
« Reply #2 on: November 03, 2009, 11:26:32 pm »
17?!?!?!?
My worst was 20 with my old cracked head. No compression meant it drank a lot of fuel.
They way it is now with the aaz head, 2.5 inch straight exhaust - split to in front of rear tires, gov, lots of fuel, boost pin at MAX i was getting between 28-35 and i was driving it like i stole it.
I'm thinking to reach 17 i need a bigger pump head!!! and a lift pump...
both things that are currently on my agenda :P ;)
Reply #3November 04, 2009, 09:19:45 pm
diesel smoke
  • 209
« Reply #3 on: November 04, 2009, 09:19:45 pm »
I can get 15MPG in the bus.  :P  :D But that's an old air cooled flat 4.  ;)
In the IDI I got something near 30 once with a lot of idling in the winter. In the TDI something in the high 30's, again, a lot of idling in the winter. :)
'99.5 Bora TDI
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
Reply #4November 05, 2009, 11:56:44 am
catlin_cava
  • 1954
« Reply #4 on: November 05, 2009, 11:56:44 am »
when your reving at 3500 to 4000 RPM at 110 lol
Catlin
Reply #5November 05, 2009, 04:06:27 pm
« Reply #5 on: November 05, 2009, 04:06:27 pm »
In the flat red bunny after the gov mod and fuel screw I would consistantly get 38MPG...it sucked. I think the pump was going out though.
Reply #6November 05, 2009, 04:39:49 pm
Syncroincity
  • 727
« Reply #6 on: November 05, 2009, 04:39:49 pm »
If you're sitting still with the engine running, you're getting zero miles per gallon. :D
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #7November 05, 2009, 08:06:59 pm
« Reply #7 on: November 05, 2009, 08:06:59 pm »
I worked out something with a short test today.. with my 410k 81 running out of a graduated cylinder, at idle it burned 250ml in 20 minutes.. 12.5ml/minute OR 4.8ml every second. Those are some good numbers. So theoretically!!! you could idle for roughly 80 minutes on just one liter of fuel :) lol
Reply #8November 06, 2009, 01:23:10 am
maxfax
  • 2126
« Reply #8 on: November 06, 2009, 01:23:10 am »
I had a Mustang once upon a time that 0mpg was actually good...
Reply #9November 06, 2009, 09:22:16 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #9 on: November 06, 2009, 09:22:16 am »
Don't you mean .208 ml/second?
Calvin
91 VW Golf 1.6NA 5spd
Reply #10November 06, 2009, 06:00:14 pm
Syncroincity
  • 727
« Reply #10 on: November 06, 2009, 06:00:14 pm »
Haha, yeah, we used to have a Chrysler Cordoba (minus the Corinthian leather, unfortunately) with a 440 in it. It was more useful to measure gallons per mile. :P
JC McCavitt
'98 Jetta Wolfie
Reply #11November 07, 2009, 02:33:47 pm
« Reply #11 on: November 07, 2009, 02:33:47 pm »
haha yes lol
Reply #12November 08, 2009, 01:19:09 am
tSoG-84bit
  • 188
« Reply #12 on: November 08, 2009, 01:19:09 am »
got about 34mpg, one time in my 04 TDI, but that was carrying two friends that weigh about 260 each, along with two sets of tools, each about 50 pounds, along with a set of 13" alloys, with tires, a cabby bumper, with tow bar setup. Oh yeah, and a rooftop clamshell, that had the rear beam, control arms, and all four struts for a rabbitGTI. I'm not gonna say exactly how fast our average speed was, but it wasn't slow.
We actually got about the same mileage when we bolted all the above mentioned parts to our race car shell, and towed it home.
First time I got less than 600 miles per tank... :(
84bit 1.6na
Engine died, pulling it apart, putting something new in it's place.
Reply #13November 08, 2009, 05:45:23 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #13 on: November 08, 2009, 05:45:23 pm »
worst i've ever had was 35mpg... basically stock aaz with fuel screw wound a ways in. no extra boost, no other mods.
worst i ever got n/a was about 38mpg in a 1.5 n/a mk1.
'91 Golf Cabrio 1.9TD
Reply #14November 20, 2009, 09:24:35 am
« Reply #14 on: November 20, 2009, 09:24:35 am »
i can get about 30 with a smoke screen behind me in my rabbit with an AUG
i can get about 30 if i baby the hell out of it in my gas GTI w/ the ACN
i cant justify keeping a gas engine in there, it has less power and gets worse mileage.
