Author Topic: 1.9 AAZ / K03 TURBO OIL RETURN LINE  (Read 5095 times)
October 31, 2009, 05:04:22 pm
GEE-BEE
  • 1604
« on: October 31, 2009, 05:04:22 pm »
I have another option to get away from the banjo bolt / fitting on the AAz block
Jic ( flare -8 ) adapter with a Metric-18 oring 90 degreee adapter for the engine block
Tompkins industries Model # 7801-8-18
tompkinsind.com
Fitting adapter for K03 Turbo (  two hole flange adapter ) to -8 an hose assy
Ebay item 380165103939 14.99
The hose you can use is Straight to straight flared -8 ( 1/2) I.D.
The hose should be measured from Flare to Flare on the two above fittings
This is a Expensive option
Teflon Hose assys can be ordered with either S/S fittings or alloy fittings
Teflon hose is -65 to +450
WITH OR WITHOUT FIRE SLEEVE( 2500 DEGREE TEMP RATING )
Iam going with Ae466 type hose from Aircraft spruce, it can be ordered in Blue or brown Intergal firesleeve ( hose and firesleeve are bonded together )
Aircraftspruce.com
search AE466
I hope this helps !
is any one doing a AAZ build with a K03 ?
P.S. i did think of using a straight adapter on the block, But a 90 degree hose fitting  is more expensive
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1November 01, 2009, 02:04:51 pm
stewardc
Re: 1.9 AAZ / K03 TURBO OIL RETURN LINE
« Reply #1 on: November 01, 2009, 02:04:51 pm »
Try your local hydraulic hose supplier. They have an amazing supply of hoses and fittings. My supply and return lines (to a Garrett T3 on an AAZ) were not that expensive and he had all the right fittings at a bargain price.
Reply #2November 03, 2009, 12:22:36 pm
87octane
« Reply #2 on: November 03, 2009, 12:22:36 pm »
I've got a T3 on an AAZ, but my ACME oil pan (vw TD -> zuki chassis) has a simple open pipe return welded in. So for this iteration, the block will be plugged.
Reply #3November 03, 2009, 12:45:22 pm
stewardc
« Reply #3 on: November 03, 2009, 12:45:22 pm »
That's how mine started out. I just bought a new pan, had it powdercoated and will put the return back in the block this winter.
