Author Topic: another "what turbo is this"  (Read 6541 times)
October 18, 2009, 07:07:02 am
1outof5
« on: October 18, 2009, 07:07:02 am »
I've been given this newly rebuilt turbo, it's a Garrett (writen on the housing) but that's all I know.
The usual green tag is no longer there an in it's place there's a piece of sheet metal with a "serial" number that's partly visible (looks like it was hand engraved). Can any one tell what it is? The information from the gift bearer is that it came out of a passat AAZ but I have my doubts as I thought that the AAZ only came with a K14. Is this a T2?
Reply #1October 18, 2009, 10:42:47 am
Re: another "what turbo is this"
« Reply #1 on: October 18, 2009, 10:42:47 am »
thats a trapezoid T3 flange on there it looks like. its a T3 tho for sure. the junk one i used to have looked just like that. looks like its just a stock 1.6 turbo.
Reply #2October 18, 2009, 10:52:35 am
MJF
  • 581
« Reply #2 on: October 18, 2009, 10:52:35 am »
Itīs not, T3, T2 it is.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #3October 18, 2009, 10:53:45 am
« Reply #3 on: October 18, 2009, 10:53:45 am »
wheres the T2 flange? and the water cooling? thats the oil feed line you see in the picture.
Reply #4October 18, 2009, 10:56:38 am
MJF
  • 581
« Reply #4 on: October 18, 2009, 10:56:38 am »
What T2 flange? All 1,6 turbos and 1,9 K14&T2 share same flanges. AAZ T2 is not water cooled. Here is 1,6 T3, donīt mind vnt20 on right.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #5October 18, 2009, 04:46:39 pm
idgtd
  • 86
« Reply #5 on: October 18, 2009, 04:46:39 pm »
It's not a stock 1.6 T3. Center section looks different, and it has a different wastegate actuator.
Stephen Phillips
1981 VW Rabbit Diesel (mit turbolader)
1985 VW Scirocco Wolfsburg Ed.
1970 Porsche 911T
1972 MG Midget
1996 Chevy C3500 Dually
1930 Model A Ford
Reply #6October 18, 2009, 07:43:49 pm
blackdogvan
  • 574
« Reply #6 on: October 18, 2009, 07:43:49 pm »
T2
1991 Vanagon 1.9 mTDI
Reply #7October 19, 2009, 01:57:29 am
1outof5
« Reply #7 on: October 19, 2009, 01:57:29 am »
so T2 then!
what are the differences between a "standard" T2 and a watercooled T2? (yes I know the watercooled T2 is watercooled  ;D)
What would be better for a 1.6 TD front mounted IC, Giled pump, 15/18psi ? Its for my daily driven caddy.
If the watercooled T2 is a better option are the parts interchangeable, like taking the parts of the H2O T2 and putting them on the "standard" T2 (as it has just been rebuilt so like new)?
Reply #8October 19, 2009, 07:07:44 am
« Reply #8 on: October 19, 2009, 07:07:44 am »
I wouldn't mess with it, too small.  18psi would be out of it's efficiency range for sure.
Reply #9October 19, 2009, 09:13:04 am
wildenbeast
  • 50
    • The WILDENBEAST
« Reply #9 on: October 19, 2009, 09:13:04 am »
I have this same turbo set up with a Giles pump and a Saab intercooler.   You didn't say what vehicle you were going to install it on???  I have this setup on a Vanagon Syncro with a high top.  I have been told that the T2 is very similar to a K14; performance-wise.  As Andrew pointed out, it spools quickly which is really great for altitude and in my case- the mountains of CO.  I have mine setup for 17psi of boost right now.  The only drawback; I am fairly convinced that using such a small turbo helps heat up my oil much faster than if I were to use something like a K03.
Bill
1990 Syncro Adventurewagen
1.9 Turbo Diesel (AAZ)
http://billwildenberg.shutterfly.com/vwvanagon
Reply #10October 19, 2009, 09:25:42 am
blackdogvan
  • 574
« Reply #10 on: October 19, 2009, 09:25:42 am »
Bill
What are the boost charasteristics of that setup? Boost vs rpm & boost on the highway cruising? My understanding is the T2 is good & happy at 20psi. Maybe pushing its efficiency there but as Andrew said above, nice & driveable.
Reply #11October 19, 2009, 09:31:23 am
wildenbeast
  • 50
    • The WILDENBEAST
« Reply #11 on: October 19, 2009, 09:31:23 am »
I am in the process of sorting out my tachometer so I can't answer the first question.  I would say that for hwy cruising, I am between 5-10psi and only get above 14psi when I am climbing a long grade.  I know of another person that ran the T2 on a Syncro Westy at 20psi with good results.
Reply #12October 19, 2009, 10:22:15 am
wildenbeast
  • 50
    • The WILDENBEAST
« Reply #12 on: October 19, 2009, 10:22:15 am »
I'm sure it does heat up the oil more than a more efficient turbo would, but the K03 would be similar.  You'd have to go with a k24 or T3 which in a vanagon at altitude have unbearable lag.  Those are all the reasons that I'm happy to deal with the added complications of VNT turbos.
Is there a reason that you have not tried a GT series turbo from Garrett?  They seem to have fast spooling, ball bearings (that are both oil and water cooled), and have plenty of power.
http://www.turbobygarrett.com/turbobygarrett/products/turbochargers.html
