Author Topic: Rear disk Brake conversion  (Read 4718 times)
August 24, 2009, 04:44:05 am
catlin_cava
  • 1954
« on: August 24, 2009, 04:44:05 am »
How hard is it going to be to convert my rear drum brakes to Disk? I have a 98 Wolfsburg with rear disk Brakes on it and I'm thinking of ripping them off and putting them on the Golf. Will it work or am I setting up for disaster.
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #1August 24, 2009, 03:11:28 pm
Re: Rear disk Brake conversion
« Reply #1 on: August 24, 2009, 03:11:28 pm »
Cake!!!
Do your swap.  Best to get the proportioning valve and master cyl as well as the master is larger for the 98.
Reply #2August 24, 2009, 03:27:32 pm
catlin_cava
  • 1954
« Reply #2 on: August 24, 2009, 03:27:32 pm »
So the rear disk and calipers will bolt right up? to the brake lines
Catlin
Reply #3August 31, 2009, 06:56:33 pm
« Reply #3 on: August 31, 2009, 06:56:33 pm »
No they wont. You need the hard lines that are mounted to the rear axle for a rear disk application as well. Rubber lines from them to the calipers.
Have you ever seen hard lines to a caliper?  I sure haven't.
Basically you need everything from a disk brake car to convert yours in order to do it correctly.
« Last Edit: August 31, 2009, 07:02:23 pm by zukgod1 »
Reply #4September 01, 2009, 04:40:45 pm
catlin_cava
  • 1954
« Reply #4 on: September 01, 2009, 04:40:45 pm »
How hard just to Swap the Rear Axel? lol I have the WHOLE car lol
Catlin
Reply #5September 02, 2009, 10:39:07 am
xxkoadyxx
  • 179
« Reply #5 on: September 02, 2009, 10:39:07 am »
there a company out there that makes a drum to disc convertion kit for $499.99 USD its not no brembo brakes but is much better then the drums, because drums a dumb..lol..I think they are made by MSD i think, but comes with caliper, disc, caliper mount, and lines, i think, not sure, would have to look into ur self, but that is u want new.
93 vw Golf 1.9TD soon to be stage 3 malone TDi (project)
2003 VW 1.8T Passat (daily)
Reply #6September 02, 2009, 10:42:27 am
xxkoadyxx
  • 179
« Reply #6 on: September 02, 2009, 10:42:27 am »
Reply #7September 02, 2009, 01:08:52 pm
« Reply #7 on: September 02, 2009, 01:08:52 pm »
It wouldn't be to hard to swap the axle as long as it's the same width etc etc.
Still need the prop valve and master cyl to make it a complete conversion.
Reply #8September 04, 2009, 01:05:22 pm
catlin_cava
  • 1954
« Reply #8 on: September 04, 2009, 01:05:22 pm »
I have a 98 Jetta Wolfsburg that i'm getting ready to Part Out. I would have all the parts I need to swap it, i just want to try and figure out what kind of job i'd be getting my self into/
Catlin
