Author Topic: gtd swap for na  (Read 4393 times)
July 10, 2009, 10:36:41 pm
vwjones
  • 80
gtd swap for na
« on: July 10, 2009, 10:36:41 pm »
i got a gtd with factory intercooler that i'm swapping into my 81 NA caddy.  fabbing a 2.5 inch downpipe and exhaust too.  having trouble finding much out about the gtd's.  cool engine though, it has a pump to water cool the turbo.  almost finished with all the mods to put it ( egt, boost, oil temp gauges air ducting etc) starting to get pretty excited.  question that i have is what is the timing supposed to be set at with the GTD?  I've heard they have different injectors and was wondering if breaking pressure is different
Reply #1July 11, 2009, 02:12:39 pm
1outof5
Re: gtd swap for na
« Reply #1 on: July 11, 2009, 02:12:39 pm »
gtd  with IC in a caddy is  8)
and yes the GTD engine has an IC, "bigger" (more flow) injectors different pump, water coolled turbo
the injectors are factory set for 155bars
are you installing the IC on top of the engine or in front of the radiator (better option)
don't forget the pictures
Reply #2July 11, 2009, 08:17:52 pm
vwjones
  • 80
Re: gtd swap for na
« Reply #2 on: July 11, 2009, 08:17:52 pm »
i'm installing it top mount.  I know the purists are shuddering right now, but It gets hot here in missouri and i'm old and i want an air conditioner.  i'm installing a hood scoop to ram air through the intercooler as well as a fan underneath that pulls air through the intercooler any time the ignition is on.  thought about a temp sensor at first, then i figured that there is never going to be a time when the fan doesn't need to be on.  guess i'll set the time at .95 or so and try that out.  i'll get some pics together soon and put them up.  I know it's cool to lower a caddy, but i raised mine since i'm not cool.  i just like the way it looks better.  plus the passat wheels and tires fit now too
Reply #3July 12, 2009, 06:32:07 am
hamradio
  • 282
Re: gtd swap for na
« Reply #3 on: July 12, 2009, 06:32:07 am »
Umm, how'd you get your hands on a GTD in the US?  What was the car?  mk2?
Reply #4July 12, 2009, 06:45:28 am
1outof5
Re: gtd swap for na
« Reply #4 on: July 12, 2009, 06:45:28 am »
...  I know it's cool to lower a caddy, but i raised mine since i'm not cool.  i just like the way it looks better.  plus the passat wheels and tires fit now too
so how did you raise the front?
Reply #5July 12, 2009, 12:14:52 pm
Re: gtd swap for na
« Reply #5 on: July 12, 2009, 12:14:52 pm »
probably coil spacers or different coils i would assume, since those are about the quickest, easiest, and cheapest methods.
i want a 4x4 vw pickup.
put sammy running gear under it or something. and build some sort of a tube sub frame?
Reply #6July 12, 2009, 12:21:15 pm
airhead
Re: gtd swap for na
« Reply #6 on: July 12, 2009, 12:21:15 pm »
Why not just buy a Syncro pickup?
Something like this...
Reply #7July 12, 2009, 12:31:37 pm
Re: gtd swap for na
« Reply #7 on: July 12, 2009, 12:31:37 pm »
because those are basically made out of unobtanium here in the united states. and besides, thats a vanagon, and i hate vanagons.
Reply #8July 12, 2009, 12:33:37 pm
airhead
Re: gtd swap for na
« Reply #8 on: July 12, 2009, 12:33:37 pm »
Well then try to put Golf country syncro running gear into a caddy. That might be a bit easier, but getting a Golf syncro would be harder.
Reply #9July 12, 2009, 12:38:46 pm
catlin_cava
  • 1954
Re: gtd swap for na
« Reply #9 on: July 12, 2009, 12:38:46 pm »
or just wait ti;ll 2010 and buy this
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #10July 12, 2009, 12:39:25 pm
catlin_cava
  • 1954
Re: gtd swap for na
« Reply #10 on: July 12, 2009, 12:39:25 pm »
Or find a Passat syncro and get the drive shaft shorten
Catlin
Reply #11July 12, 2009, 12:53:43 pm
Re: gtd swap for na
« Reply #11 on: July 12, 2009, 12:53:43 pm »
but all those options you just listed off, all have one major problem. they are all independant suspension. if i were to build a 4x4 VW, it would not be independant. i would put some sort of small straight axles in it. and mount the engine lengthways. if you can put a VW engine in a sammy, why cant you take the running gear out of a sammy and put it in a VW? i think it would be dope as hell seeing a rabbit or caddy pull up on some 31" mudders. if i ever had something like this, i would definitely use the 4 wheel drive too. think of the dopeness, a VW with hubs and a transfer case.
Reply #12July 12, 2009, 01:08:21 pm
catlin_cava
  • 1954
Re: gtd swap for na
« Reply #12 on: July 12, 2009, 01:08:21 pm »
I think it would look Awesome  ;D
Catlin
Reply #13July 12, 2009, 01:23:23 pm
Re: gtd swap for na
« Reply #13 on: July 12, 2009, 01:23:23 pm »
right? cause the golf syncros look pretty ***in, and they still have little street tires on them. some 29 x 9.50 super swampers would be amazing. you would have enough torque and traction to climb a damn tree.
Reply #14July 12, 2009, 01:43:01 pm
catlin_cava
  • 1954
Re: gtd swap for na
« Reply #14 on: July 12, 2009, 01:43:01 pm »
I had that though last year...Except it was Toyota from and R24 motor and 5 speed, with a MK3 Golf Body on it...didn't have room to do the work
Catlin
