Author Topic: 82 Audi 5000 Turbo Diesel.  (Read 32521 times)
Reply #15July 13, 2009, 05:25:30 am
ObscuredByClouds
  • 98
Re: 82 Audi 5000 Turbo Diesel.
« Reply #15 on: July 13, 2009, 05:25:30 am »
Audi 5000's are awesome.
Reply #16July 13, 2009, 10:33:11 am
« Reply #16 on: July 13, 2009, 10:33:11 am »
...WOAH! clear over in finland tho? that would be hell for shipping.
and im pretty sure it probably is just a HG. the owner said that there is oil in the coolant, and he said it pressurizes the coolant. and with a cracked head, usually it will act normal until it gets warmed up a bit. then it will start leaking and pressurizing stuff.
Reply #17July 13, 2009, 03:24:43 pm
colectb
  • 93
« Reply #17 on: July 13, 2009, 03:24:43 pm »
The 5000 Turbo Diesels were only made in 83.... I have 2 of them and neither run. I wouldn't eliminate that its a cracked head, that's the Achilles heel of these cars. I also have an 80 5k with an 83 TD engine and a manual. I DEFINITELY would NOT recommend the NA diesel manual, it is geared very low. I would still pick up the car though, that price is good, I have heard there were only 500 of these cars imported to the U.S.
And yes, heads are a HUGE chore to find, I need two of them. A bit OT, but does anyone know a place that can redo cracked audi heads?
And the quattro question, it may be easier to transplant the diesel into a later audi quattro, here is a thread from the guy I bought my 1980 5000 from.
http://www.motorgeek.com/phpBB2/viewtopic.php?t=17930
My car is actually in the second picture, the one with the SAAB wheels
« Last Edit: July 13, 2009, 03:27:25 pm by colectb »
1986 Porsche 944 NA
1983 Audi 5000 Turbo Diesel
Reply #18July 13, 2009, 04:02:01 pm
Turbinepowered
  • 1206
« Reply #18 on: July 13, 2009, 04:02:01 pm »
Cracked between the valves? Can't any good aluminum welder fill those cracks?
Reply #19July 13, 2009, 06:09:10 pm
« Reply #19 on: July 13, 2009, 06:09:10 pm »
I think you "CAN" weld it back up, but it will more than likely crack again, won't it?
Reply #20July 13, 2009, 08:46:57 pm
Turbinepowered
  • 1206
« Reply #20 on: July 13, 2009, 08:46:57 pm »
Weld it up then send it out to get the exhaust port ceramic coated to decrease the heat differential across that thin bit of metal? And while you're at it, send out to get the pistons ceramic coated and skirt treatment? :D
Reply #21July 14, 2009, 03:57:31 am
MJF
  • 581
« Reply #21 on: July 14, 2009, 03:57:31 am »
Head can be welded, it'll be as good as new. New 4-cyl head is cheaper to buy than fix several cracks, but 5-cyl could be different story.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #22July 14, 2009, 10:53:25 am
« Reply #22 on: July 14, 2009, 10:53:25 am »
if the head had been doing crack, i will just weld it up, i have a grinder and a welder. i can do anything.
Reply #23July 14, 2009, 11:21:15 am
TurboJ
  • 661
« Reply #23 on: July 14, 2009, 11:21:15 am »
ive got plenty of vw's tho. and i know vw diesels are pretty indestructible. im not so sure about the slush box its got in it. im probably going to end up building some sort of 5 speed trans out of a GT coupe or 5000 non quattro or something. why would it take a service lift to keep it on the road? ive been wrenching for almost 10 years, and have never NEEDED a lift for anything. theres no quattro to maintain or anything like that.
Well, the 5000 does have a bit more room under the hood but at least with a 5-cylinder typ89, you have to do a lot of servicing from under the engine bay. Need to change an oil filter? Or tighten your belts? etc, you need to get under the car and take the bottom air dam off to gain access to anything...   Yes I know the 5000 is a bit different, but my point is these Audis are more involving to service / repair than VWs.
Jetta II 1.6 TD 'Project 200'
Reply #24July 14, 2009, 11:38:08 am
« Reply #24 on: July 14, 2009, 11:38:08 am »
ok, thats fine. im used to getting under rigs to maintain them. i spend as much time under my 4runner as i do driving it, it seems like anyway. and if the oil filter is too much of a *** to change, i will just put a remote filter mount setup on it, thats what i did with my runner. they mount the filter on the front drivers side of the engine, behind an engine mount, and basically up side down. its stupid trying to thread a filter *full of oil* onto the flange that points up. when i get a vehicle, its always hard to work on at first, then i work on it, figure things out a little bit, and then i learn how to do things way easier.
Reply #25July 14, 2009, 12:01:59 pm
airhead
« Reply #25 on: July 14, 2009, 12:01:59 pm »
I always hated that upside down oil filter business on my MGB. It was such a mess trying to change the filter and oil used to go everywhere. I never bothered my arse trying to put oil in the new filter before screwing it on. I just cranked the engine with the main HT lead disconnected to get the oil flowing a bit, and then started it up and the gauge used to fly up almost immediately, which in my book is fine. On my Syncro it was a bit better but was still messy business. The only car I had that had no oil filter hassle was my 74 bay window bus, and thats cause it didnt have an oil filter!
Reply #26July 14, 2009, 12:42:49 pm
« Reply #26 on: July 14, 2009, 12:42:49 pm »
it did too have an oil filter. not a spin on one like we are used to. you remove those 6 bolts around the oil plug and under that round plate is the oil filter.
Reply #27July 14, 2009, 02:30:12 pm
airhead
« Reply #27 on: July 14, 2009, 02:30:12 pm »
Thats not called a filter. Its called a strainer. Its just a piece of dome shaped gauze really. I used to rinse that in petrol and put it back in. It wasnt necessary to replace it (even though I did anyway on one of the oil changes). Its the reason why the damn thing needed an oil change every 3000 miles. A right pain in the arse.
Reply #28July 14, 2009, 03:12:51 pm
MJF
  • 581
« Reply #28 on: July 14, 2009, 03:12:51 pm »
Quote from: TurboJ
So you are saying that not to get Audi becouse you need to do some things from under the car? ::)  I´ve never liked transversed engines, longitudal are much easier to work ;D
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #29July 14, 2009, 04:12:26 pm
colectb
  • 93
« Reply #29 on: July 14, 2009, 04:12:26 pm »
+1   And seriously, the oil filter is a piece of cake. Also if you pick up a good Bentley manual (one can be had for less than $30) you will have everything covered. The engine is relatively simple and you would be surprised how many parts are interchangable with the VW 1.6. Best of luck with the car! And if you ever need help or parts, PM me! I'm no expert, but I have quite a few parts lying around.
1986 Porsche 944 NA
