Author Topic: best spot to tee in an oil pressure gauge  (Read 12186 times)
Reply #15July 01, 2009, 06:55:23 pm
jasonsansfleece
  • 162
Re: best spot to tee in an oil pressure gauge
« Reply #15 on: July 01, 2009, 06:55:23 pm »
 VDO make a sender with two terminals, one for the gauge and one for the idiot light. The idiot light will switch on at 7lbs. The sender has the correct thread for the cylinder head.
http://www.egauges.com/vdo_send.asp?Sender=80PSI_5Bar_VDO
Check out # 360-006  $25
Guy
« Last Edit: July 01, 2009, 07:01:57 pm by jasonsansfleece »
Reply #16July 01, 2009, 08:52:33 pm
92EcoDiesel Jetta
« Reply #16 on: July 01, 2009, 08:52:33 pm »
Guy
Jason, 360-006 will work if I have the electric gauge that works with it. But I don't.
This VDO Tee # 240-850 will do the job and is priced more reasonably at $7.50. http://www.42draftdesigns.com/categories/products/vdo/vc240850.htm
« Last Edit: July 01, 2009, 08:56:53 pm by 92EcoDiesel Jetta »
Reply #17July 01, 2009, 09:29:31 pm
« Reply #17 on: July 01, 2009, 09:29:31 pm »
I used a tee with 1/8npt and screwed it right into the head, napa has 'em. I didn't think it was the correct threads but it was so close I didn't know what else it could be.
A few years ago I was putting an oil pressure gauge on a subaru justy which goes into the cast block, so I went to napa to find out what kind of threads it was supposed to be and he said 1/8npt. I tried forever to get it to thread in and finally went back and told him that so he looked it up and said yup 1/8npt. I ended up running an 1/8npt tap in there.
So I bet he played my ignorance and it was supposed to be m10x1.
Is the aluminum head or brass threads stronger?
My brother put a gauge on a jap gasser with like a 3 inch long straight extension and it broke off in no time, try to keep it as short as possible.
Reply #18July 08, 2009, 02:54:56 pm
92EcoDiesel Jetta
What do you think?
« Reply #18 on: July 08, 2009, 02:54:56 pm »
What do you think of this location for the oil pressure gauge? Also, what's the best way to run the 1/8" nylon line from the engine bay into that area behind the switches?
Reply #19July 08, 2009, 04:02:53 pm
92EcoDiesel Jetta
« Reply #19 on: July 08, 2009, 04:02:53 pm »
I poked around and it looks like the easiest way in is through the speedo cable opening. What do you think?
Reply #20July 09, 2009, 08:54:24 am
« Reply #20 on: July 09, 2009, 08:54:24 am »
thats how i did it, just run it right beside the speedo cable. thats how my plastic boost gauge is ran into my car.
Reply #21July 09, 2009, 02:28:51 pm
92EcoDiesel Jetta
« Reply #21 on: July 09, 2009, 02:28:51 pm »
I've got the gauge plumbed in but not mounted. Started it up to check for leaks and there was none. 60 psi engine dead cold with Rotella 15W40. Is that about right or low? I don't really like having engine oil running into the cabin. Anyone use a thing called an isolator?
Reply #22July 09, 2009, 02:59:00 pm
« Reply #22 on: July 09, 2009, 02:59:00 pm »
60 cold sounds a bit low to me, I get 95-100 cold, doesn't matter though hot is what matters.
Oil running into the cabin won't hurt a thing unless you spring a leak.
Reply #23July 09, 2009, 04:13:41 pm
92EcoDiesel Jetta
« Reply #23 on: July 09, 2009, 04:13:41 pm »
Where did you plumb your gauge? Oil filter or cyl head. The 60 psi cold was at idle, taken at the oil filter (in lieu of the pressure switch). I will move it to the cyl head tomorrow and see what it reads there.
Reply #24July 10, 2009, 11:35:35 am
92EcoDiesel Jetta
« Reply #24 on: July 10, 2009, 11:35:35 am »
At hot idle it's about 15 psi, 55 mph in 4th it's 30 psi. I'm not sure how accurate this cheapo gauge is. Are these numbers within spec? I've heard 10 psi per 1000 rpm but I don't have a tach. What rpm is my engine at 55 mph in 4th?
Reply #25July 11, 2009, 10:42:29 am
« Reply #25 on: July 11, 2009, 10:42:29 am »
Mine is in the head.
Spec is something like 28psi @ 2000rpm.
Look on your tranny bellhousing, there's a 2-3 letter code, look that up on http://www.scirocco.org/gears/
I would think it's around 2200rpm @ 55, check though ;).
Reply #26July 11, 2009, 09:49:23 pm
« Reply #26 on: July 11, 2009, 09:49:23 pm »
I was wrong with the numbers I gave earlier, I was thinking 5th gear @ 55, in 4th it's probably 2900-3100rpm.
If the numbers you gave were taken from the head then it's rather low.
Reply #27July 12, 2009, 11:19:10 am
« Reply #27 on: July 12, 2009, 11:19:10 am »
i just read someone elses post on here, and just like i figured, the pressure is the same reading at the filter flange and at the head. there was maybe a 1-2psi difference, but it was basically the same reading. both at idle and revved up going down the highway.
Reply #28July 12, 2009, 07:02:37 pm
92EcoDiesel Jetta
« Reply #28 on: July 12, 2009, 07:02:37 pm »
The only difference I noticed was the oil pressure came up faster at the oil filter than at the cyl head.
Reply #29July 13, 2009, 11:17:04 am
« Reply #29 on: July 13, 2009, 11:17:04 am »
no way? couldnt be that the oil pump is 3 inches away from the filter flange? and the oil pump is like 15 inches from the head?
