Author Topic: best spot to tee in an oil pressure gauge  (Read 12605 times)
Reply #30July 13, 2009, 11:24:29 am
92EcoDiesel Jetta
Re: best spot to tee in an oil pressure gauge
« Reply #30 on: July 13, 2009, 11:24:29 am »
At the oil filter, the needle moves almost instantaneously after engine starts. At the cyl head, there's approx a 1/2 second delay.
Reply #31July 13, 2009, 11:40:44 am
92EcoDiesel Jetta
« Reply #31 on: July 13, 2009, 11:40:44 am »
I calibrated my cheapo oil pressure gauge to a Mercedes 300D oil pressure gauge. My gauge was reading low. I calibrated it by twisting the Bourdon tube a little by reaching in the light bulb hole with long nose pliers. After calibration, at idle I am now reading 20 psi and at 60 in 5th I am reading 35 psi. I am going to plumb in the Mercedes oil pressure gauge temporarily to double check that I calibrated the cheapo gauge "good enough".
Reply #32July 13, 2009, 12:49:52 pm
« Reply #32 on: July 13, 2009, 12:49:52 pm »
35psi is way way low oil pressure for cruising. what kinda oil u running?
Reply #33July 13, 2009, 06:18:46 pm
92EcoDiesel Jetta
« Reply #33 on: July 13, 2009, 06:18:46 pm »
If I get the rpm up, say 3rd gear at 55 mph I can get the oil pressure up to 60 psi, In 5th at 60 it's betwwen 30 to 35 psi.
Reply #34July 14, 2009, 10:58:29 am
« Reply #34 on: July 14, 2009, 10:58:29 am »
35 psi at 3500 rpms for a hyd turbo motor is just fine.
oh yea!
i totally forgot that his engine is a hydro lift engine. i forgot those things have weak oil pressure.
Reply #35July 14, 2009, 01:06:40 pm
« Reply #35 on: July 14, 2009, 01:06:40 pm »
10 psi pr 1000 rpm is a very good rule to live by.
Reply #36July 15, 2009, 12:48:32 pm
92EcoDiesel Jetta
« Reply #36 on: July 15, 2009, 12:48:32 pm »
I ended up using all 1/8 NPT, a 1/8 NPT hydraulic steel nipple for strength into the head and a 1/8 NPT brass Tee. So far so good- no leaks. I think the parts are sufficiently strong to not have any problems down the road but I'll still keep an eye on it..
Reply #37July 15, 2009, 07:27:31 pm
« Reply #37 on: July 15, 2009, 07:27:31 pm »
Hmmm... does your oil light still come on when you first turn the key to "on"?!
Reply #38July 15, 2009, 07:32:53 pm
92EcoDiesel Jetta
« Reply #38 on: July 15, 2009, 07:32:53 pm »
Yes it does. Why do you ask?
Reply #39July 15, 2009, 10:30:42 pm
« Reply #39 on: July 15, 2009, 10:30:42 pm »
Lots of folks run into sensor grounding problems when they use Teflon tape to seal the oil pressure fittings... sounds like you're OK.
Reply #40July 16, 2009, 07:13:31 am
92EcoDiesel Jetta
« Reply #40 on: July 16, 2009, 07:13:31 am »
I didn't cover the first 2 threads on the fitting with the Teflon tape, that insured electrical conductivity as well as keeping the Teflon tape out of the oil.
Reply #41September 16, 2009, 09:44:51 am
92-Eco
« Reply #41 on: September 16, 2009, 09:44:51 am »
I hooked a mechanical gauge up to my head port just to see what it was reading and i had 60psi upon cold start up. Once it ran for a while it dropped to 30psi and would act like a tach and go up and down with the rpms. Ive never seen an oil pressure gauge fluctuate like this but i guess it dosent matter as long as i have pressure.
