Author Topic: EGT gauge wiring autogauge metec kangertai  (Read 3574 times)
June 30, 2009, 03:59:06 am
regcheeseman
  • 714
« on: June 30, 2009, 03:59:06 am »
I've got a EGT marked as a METEC but google is telling me it's a Autogauge made by Kangertai
It has no wiring info and six wires to connect.
two - red and black look like power
two - red and black look to be pyro connection
So I'm left with a blue and a white
Any ideas or anyone got one of these guages?
Reply #1June 30, 2009, 01:41:06 pm
Re: EGT gauge wiring autogauge metec kangertai
« Reply #1 on: June 30, 2009, 01:41:06 pm »
i would be willing to bet the white is for the gauge lights.
Reply #2July 02, 2009, 04:53:14 am
regcheeseman
  • 714
« Reply #2 on: July 02, 2009, 04:53:14 am »
Would that bet cover the cost of a replacement??  ;)
Reply #3March 08, 2011, 05:14:09 am
regcheeseman
  • 714
« Reply #3 on: March 08, 2011, 05:14:09 am »
It's been a little while but I was getting round to fitting this last night and hit the same problem - so I had a play.
It seems that the small diameter red and black pair ppower the guage and it starts to cycle through the colour backlight options until you stop it with the button on the front.
Connecting the larger black and red makes the gauge spin round to maximum.
Fitting the transducer to the blue and white wires returns the gauge to it's 0 point.
SO it would seem higher resistance = higher gauge reading?
However the pyro sits at 10 ohms when cool and drops towards 0 when introduced to a hot air gun.
Any ideas to get this setup working properly - or do I just buy another?
Reply #4March 09, 2011, 10:26:50 pm
79rabbit4dr
« Reply #4 on: March 09, 2011, 10:26:50 pm »
http://en.wikipedia.org/wiki/Temperature_coefficient#Negative_temperature_coefficient
Maybe swap the ones giving you higher resistance for the lower resistance ones? Then again it's late and I don't have my electrical thinking cap on.  ???
Reply #5July 07, 2011, 02:25:57 pm
regcheeseman
  • 714
« Reply #5 on: July 07, 2011, 02:25:57 pm »
turns out the wiring was right but a hot air gun isn't good - I got the gas torch and heated the pyro until it glowed. Worked fine!
red and black were power
small red and black memory for light setting
white blue for pyro
