Author Topic: How hard can i run my td?  (Read 2887 times)
September 12, 2005, 07:00:47 pm
jetta2nv
« on: September 12, 2005, 07:00:47 pm »
I have a 83 audi 5000td, i wanted to know if the diesel engine can handle being run hard. I dont abuse the car at all and i keep the oil changed etc. But i do floor it quit a bit and rev it to the upper rpm's. The car only has 97k on it and does not use any oil. How do you guys think it will hold up?
Reply #1September 12, 2005, 07:32:10 pm
SMOKEYDUB
  • 630
« Reply #1 on: September 12, 2005, 07:32:10 pm »
I know its not the same car but i had a 86 jetta 1.6 td and i RAPED THAT THING! and it never burnt oil,always started but i went through lots of trannys  (5 to be exact in one year)
Cheers
Jeff
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #2September 13, 2005, 12:11:16 am
Cheesetoast
  • 285
« Reply #2 on: September 13, 2005, 12:11:16 am »
i have a 93 1.9td with 263,000km, i don't redline it or high rpm until the oil's reached at least 180f.  I occasionally go for some fun acceleration, and the odd highway run to 190kmph, but lately it's been shifting at 2000rpm and light footed, diesel is $1.14/L canadian :(
Most important is letting the fluids warm up first.
Reply #3September 13, 2005, 01:58:11 am
v8volvo
  • 71
    • http://www.cardomain.com/profile/v8volvo
« Reply #3 on: September 13, 2005, 01:58:11 am »
Yep. Diesels like to run hard, but ONLY after FULLY warmed up. If you stomp on it cold, you will cause all kinds of problems, including cracked cylinder head and tapered bores. Proven on Volvo diesels, which is your Audi five plus one more cylinder.
Reply #4September 16, 2005, 10:46:27 am
DutchTouch
  • 17
« Reply #4 on: September 16, 2005, 10:46:27 am »
Don't do it!
I had an  '83 Audi 5000td for 10 years.  This motor is not intercooled and it was VW/Audi's first attempt at a turbocharged motor.  The key is to watch your oil temperature gauge and what it is doing. There is a "normal" range that the temps sits at, I believe its at 90 C or 195 degrees, which is the first "tick" mark on the gauge.  If you drive over about 60 to 62 mph, the needle  will come off of that mark and that means your oil is getting too hot and creating problems with your engine.
This car is very heavy, especially for a 2.0 litre motor, and it was designed  for when the speed limit in the USA was 55 MPH.  You push it much harder and you will have problems.  These motors will crack heads betwen the valve seats if run too hard or used for trailering.  Even trailering my 2  550 jetskis was too much for my CA  Audi  5000 td.
Drive it  around town, drive it on highways to 62 or 3 indicated MPH, but if you want the car to last, don't do 75 in it, the tranny is only an "E" 3 speed, and running it much past 2800  RPM continous will heat soak the motor due to no intercooler.
Also, I strongly reccomend that you change out your oil and get MOBIL 1  Truck and SUV 5W-40 at Walmart, as well as use original Mann  oil filters.
The Fram 2487's are junk and don't filter out enough, they should be avoided at all cost.
I usually saw 32 to 34.5 mpg in my Audi, I think it had about a 550 to 600 mile range per tank. Still miss it, it was a great ride.
Reply #5September 16, 2005, 07:56:29 pm
jetta2nv
« Reply #5 on: September 16, 2005, 07:56:29 pm »
thats for the advice. Do you think i will help at all if i add a intercooler? I was thinking of getting one off a later 5000 turbo. My oil temp stays below the 1st mark almost all the time so it runs pretty kewl. The car weights about 2900lb, i dont think thats much for a 2.0 diesel. The MK4 jetta/ golf tdi's are about the same without much more power.  It normaly crusie at about 70mph and it seems to have pletty of power, the car has better pick up then my friends 2.0 automatic golf. It just really does not feel like it strains at all. Is there anything that i can do to prevent these problems with the car?
Reply #6September 19, 2005, 01:15:50 pm
zyewdall
  • 393
« Reply #6 on: September 19, 2005, 01:15:50 pm »
Quote from: "DutchTouch"
I noticed when looking up filters for my 1.6NA that there are two Fram #'s that fit it.  One is a little tiny one (the 2487 I think), and the other looks like it is for a V-8 engine.   Are the big ones any better?
'89 Subaru 4x4 touring wagon
1976 Ford Sasquatch pickup
Reply #7September 19, 2005, 01:41:00 pm
BlackTieTD
  • 1512
« Reply #7 on: September 19, 2005, 01:41:00 pm »
neither fram is any good in a VW. get a mann or mahle filter as specified by VW for your motor.  :)
Reply #8September 20, 2005, 02:31:26 am
  • 2744
oil filters
« Reply #8 on: September 20, 2005, 02:31:26 am »
An oil filter for a big block Ford will also fit a VW 1.6D...but the bypass valve opens up at 10 psi on the big block Ford filter and 30 on the VW diesel filter.
 This allows crap to bypass the filter media and enter your engine.
Tornado red, '91 Golf 4 door,
Fixmyvw.com
