Author Topic: Suggested oil for high mile 1.6 N/A?  (Read 17545 times)
June 27, 2009, 11:54:15 pm
Pre95
  • 81
« on: June 27, 2009, 11:54:15 pm »
I don't even know what oil is in the car currently, other then that it's black.
81 Rabbit Diesel - 250k and climbing :)
Reply #1June 28, 2009, 12:19:36 am
Re: Suggested oil for high mile 1.6 N/A?
« Reply #1 on: June 28, 2009, 12:19:36 am »
I like delo 400 15w-40 with 1/2 a quart of lucas oil stabilizer, I like thick oil ;D.
My latest mix was the delo with hy-per lube oil suppliment, I hate it. I used to cruise at 2500rpm and have 65psi oil pressure, as soon as I started using the hy-per at the same ratio it dropped to 45psi.
Next oil change is gonna be maybe a full quart of lucas ;D.
Reply #2June 28, 2009, 12:41:36 am
« Reply #2 on: June 28, 2009, 12:41:36 am »
you can run normal 30wt in these engines, and have almost nothing for oil pressure, then dump some lucas in there and have more oil pressure then you know what to do with.
Reply #3June 28, 2009, 01:25:22 am
OM617
« Reply #3 on: June 28, 2009, 01:25:22 am »
If you add Lucas, you're using the wrong oil and causing damage.
Oil additives should never be used.
Reply #4June 28, 2009, 05:40:44 am
carrizog60
  • 978
« Reply #4 on: June 28, 2009, 05:40:44 am »
whys that?
Portugal
Reply #5June 28, 2009, 05:48:52 am
OM617
« Reply #5 on: June 28, 2009, 05:48:52 am »
They are useless at best, sometimes harmful. A quart of oil is already more than half additives. Adding your own on top of it can conflict with the oil maker's intended effects, producing negative results like foaming (Lucas), sludge (anything with PTFE) and oil starvation (any oil thickener).
The oil companies have over a billion dollars towards R&D of their oils, do you really think any consumer knows better than them because a bottle on parts store shelf says it can perform some miracle?
« Last Edit: June 28, 2009, 05:52:23 am by OM617 »
Reply #6June 28, 2009, 06:29:25 am
« Reply #6 on: June 28, 2009, 06:29:25 am »
I really like good old Rotella 15-40. It is cheap and really does a good job. It is also rated for diesel, which no matter which oil you go with should say on the bottle that it is diesel rated. I have used the synthetic rotella and others, but on an engine that has any leaks it usually makes it worse. I basically don't like quaker state and castrol for brands and have usually always come back to Rotella or Valoline for conventional oils.
Whatever you like that is what you should use just make sure the rating is approved for diesel.
Reply #7June 28, 2009, 07:03:05 am
lovinthedeez
  • 489
« Reply #7 on: June 28, 2009, 07:03:05 am »
X2 for the rotella.  its stocked at most wal marts ::), super cheap,  and my 1.6 n/a with well over 200K on the clock loves it ;D
Reply #8June 28, 2009, 08:12:01 am
« Reply #8 on: June 28, 2009, 08:12:01 am »
Rotella for me as well. Synthetic in the winter for easy start ups
Reply #9June 28, 2009, 08:24:31 am
Dakotakid
  • 1240
« Reply #9 on: June 28, 2009, 08:24:31 am »
Walmart also carries Ford's Motorcraft 15/40 in the orange 5 quart container and I have been using this off and on. Last winter, it was like $2.00 less than what 5 quarts of Rotella pencils out to. I figured: it's good enough for Ford's warranty on their elaborate diesels! No ill effects in me cars.
Reply #10June 28, 2009, 12:37:45 pm
monomer
  • 414
« Reply #10 on: June 28, 2009, 12:37:45 pm »
rotella-t
the white container. for synthetics, it's eneos or royal purple. - rotella's "synthetic" is a normal group 3 oil, not a full syn.
www.michiganvw.org
Reply #11June 28, 2009, 01:45:57 pm
airhead
« Reply #11 on: June 28, 2009, 01:45:57 pm »
What is the difference between normal oil and diesel rated oil anyway? Does it make any real difference if you use petrol engine oil in a diesel engine?
Reply #12June 28, 2009, 02:19:34 pm
monomer
  • 414
« Reply #12 on: June 28, 2009, 02:19:34 pm »
yes, it does.
a diesel rated oil is rated to suspend soot particals
www.michiganvw.org
Reply #13June 28, 2009, 03:06:35 pm
« Reply #13 on: June 28, 2009, 03:06:35 pm »
The scientific fact is: VW says use any oil in the appropriate viscosity range for your climate with at least a CF rating.  Since that's a 1980's rating we go with what's available today:  anything with a CJ-4 rating or better.
That includes oils like  Delvac 1 and Shell Rotella T.  Elf makes some, Amsoil makes some, PetroCanada makes some.
Reply #14June 28, 2009, 05:41:26 pm
SolarSteve
  • 264
« Reply #14 on: June 28, 2009, 05:41:26 pm »
I use Rotella 15w40 and I change it every 2500 miles.  I can hear a difference right after the oil change!
Steve
91 Jetta 1.6 N/A
