Author Topic: Two stroke diesels???!!!  (Read 8669 times)
June 25, 2009, 08:20:05 pm
« on: June 25, 2009, 08:20:05 pm »
I just thought that i would get some discussion starting with new two stroke diesels.  i think they are the future of diesel.  what does everyone else think???  with the power to weight ratio, they would be ideal candidates for light aircraft  :)
http://ecomodder.com/forum/showthread.php/new-2-stroke-diesel-engine-cool-link-engineering-5114.html  i found some info on them there. i really like the idea of a 4 cyl diesel boxer engine with NO camshaft (YES no bent valves... EVER!) and having the ability to run in 2 cylinder mode.   :o 8) ;D
Reply #1June 25, 2009, 08:43:19 pm
Turbinepowered
  • 1206
Re: Two stroke diesels???!!!
« Reply #1 on: June 25, 2009, 08:43:19 pm »
They'll never pass emissions, not and retain any sort of power and efficiency.  :(
Reply #2June 25, 2009, 08:53:56 pm
Syncroincity
  • 727
« Reply #2 on: June 25, 2009, 08:53:56 pm »
Very cool concept! 8) Fairly low profile, maybe a little wider than a Subaru motor. Probably could be either water or air-cooled.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #3June 25, 2009, 09:51:50 pm
« Reply #3 on: June 25, 2009, 09:51:50 pm »
There's already 2-stroke diesel aircraft engines, they're pretty new but very rare due to the high cost of converting over to it. They're turbo/supercharged, V4's, individual IP's and I THINK, watercooled heads and air cooled cylinders.
This double opposed piston thing has been around for a while, I never did understand 'em ::)
And I'm sure you all know about the 2-stroke detroit diesel's.
Man I just watched the movies about this engine, sounds neat. It has an electrically assisted turbo, probably instead of using a supercharger to get it started.
« Last Edit: June 25, 2009, 10:21:01 pm by rabbitman »
Reply #4June 26, 2009, 12:10:38 am
« Reply #4 on: June 26, 2009, 12:10:38 am »
the newer technology is allowing two stroke diesels to run nearly as clean as a regular diesel.  things like oil squirting for critical components etc.  of course this means more to fail, but i'm really liking that there's no camshaft.  the less rotating equipment the better, and the fact that every 2 strokes you get power, just means that these diesels can have a big advantage now over 4 stroke gasoline engines.  2 stroke gasoline engines will never be able to meet stringent emissions requirements.
i can see about 400 hp easily from a 4 stroke diesel. :)
Reply #5June 26, 2009, 12:33:23 am
aidan
« Reply #5 on: June 26, 2009, 12:33:23 am »
http://auto.howstuffworks.com/diesel-two-stroke1.htm
Thought about this a while ago when at college. Why couldn't it work on a TDI with a different sprocket on the cam and IP, and right ecu map? Serious over-simplifying I know
« Last Edit: June 26, 2009, 12:37:24 am by aidan »
Reply #6June 26, 2009, 01:03:13 am
« Reply #6 on: June 26, 2009, 01:03:13 am »
well there would be no cam on the two stroke :)  so it would only be the crank sprocket to the injection pump sprocket.  but yes a TDI in this configuration would kick some serious butt!!!!!!!!!!!!!!  ;D
Reply #7June 26, 2009, 01:12:02 am
OM617
« Reply #7 on: June 26, 2009, 01:12:02 am »
2 strokes will not work in a modern car, they are too "dirty" and inefficient. They make about 1.8x the power of the same displacement 4-stoke, waste lots of usable air out the exhaust, require constant positive inlet air pressure (supercharger) to move air and they release raw oil into the exhaust.
That said, I love 2-stroke diesels. I'd jump at the chance to install a Detroit 453TA with Jake Brakes into a Mercedes and nothing sounds better than a race-tuned quad turbo 12V92.  ;D
http://www.youtube.com/watch?v=vJ8o1gxrW1I
Reply #8June 26, 2009, 01:13:12 am
aidan
« Reply #8 on: June 26, 2009, 01:13:12 am »
It doesn't have to be the same design as a petrol 2 stroke, have a look at that link in my last post. Instead of having the air intake in the side of the block, surely no reason the existing intake couldn't be used, and just have the cam spin twice as fast
Reply #9June 26, 2009, 01:24:06 am
OM617
« Reply #9 on: June 26, 2009, 01:24:06 am »
2 strokes by nature require positive air pressure to operate.
Reply #10June 26, 2009, 01:51:18 am
aidan
« Reply #10 on: June 26, 2009, 01:51:18 am »
Sorry didn't think right on that. Obviously the existing cam couldn't be used, but if pressurised air helps force the exhaust gas out, how about opening intake and exhaust valves near the same time.
piston at bottom of stroke>exhaust valve opens>intake valve opens>exhaust closes>intake closes>injection
Would this be possible with the right timing and a supercharger, or even a turbo?
Are there higher pumping losses normally on a 2 stroke, or is the pressurised air still metered by load?
Reply #11June 26, 2009, 03:37:58 am
airhead
« Reply #11 on: June 26, 2009, 03:37:58 am »
I dont understand why diesel 2-strokes would be any dirtier than a normal diesel. Its not like a petrol 2 stroke which is constantly blowing out unburnt petrol into the air. In diesel 2 strokes, the fuel gets burnt and gets blown out the exhaust valves by the incoming pressurised air. Sure, a bit of clean air will go out too but thats not such a big deal.
Reply #12June 26, 2009, 06:14:59 am
Turbinepowered
  • 1206
« Reply #12 on: June 26, 2009, 06:14:59 am »
It has to do with the amount of time for the combustion process. A two stroke has to do all four steps of internal combustion in two strokes, and to accomplish this they overlap a great deal. The exhaust port is uncovered well before the piston reaches BDC, and in most cases is very statically timed, so when the piston reaches it the exhaust "metastroke" has begun (Using terms from my old engineering professor's mouth). You have to accomplish exhaust, intake and compression all on that upswing, which results in a sometimes wildly varying amount of retained exhaust gasses, and your compression is going to vary with the speed of the engine. You get some of the worst airflow at the highest, power producing speeds, and the shorter effective power stroke means the need for either multiple nozzles to shove all the fuel in there at once, or one big-honkin nozzle that's going to smoke in the bottom end.
With cylinder wall ports you're going to leak some oil out of the exhaust, guaranteed. How much can be any amount greater than zero.
Reply #13June 26, 2009, 06:22:03 am
Turbinepowered
  • 1206
« Reply #13 on: June 26, 2009, 06:22:03 am »
Oh, and the OPOC has been in "development, almost ready to sell" for almost a decade now.
You may have lost the camshaft, but at the expense of doubling your piston mass and more than doubling your rod mass, which are oscillating masses and thus more power-robbing than simple rotating masses.
I get incredibly wary, snake-oil alarms going off when someone starts making claims like "4x the power and 40% fuel efficiency gains" all in one slam-home go. Yeah, it sounds cool, but so did the barrel engine.
Reply #14June 26, 2009, 08:02:01 am
« Reply #14 on: June 26, 2009, 08:02:01 am »
« Last Edit: June 26, 2009, 08:08:53 am by jtanguay »
