Author Topic: FS: Complete 1.6TD "core"  (Read 4627 times)
May 25, 2009, 05:42:00 pm
« on: May 25, 2009, 05:42:00 pm »
Cleaning out the garage. This was pulled from a 1986 Jetta TD. I've never seen or heard it run, however was told by PO that it had been parked due to a leaking IP seal. It all looks intact, and turns over freely by hand. I was holding onto this for spares for our TD Jetta, but it appears that it will not be needed.
I do not know how many miles it has; the car it came out of had 225,000 miles listed but it may not be original.
It is being sold as-is in a rebuildable/core condition. Honestly I would at least pull the IP and reseal. All accessories are included, which means with a little cleanup and work this is essentially a complete swap.
This motor has a ton of somewhat rare TD parts that could also be used to do a full NA->TD conversion.
All this needs to run as a swap would be the glow plug relay wired up OR 12V supplied to the glow plug bus via a switch, and 12V to the fuel shutoff solenoid at the injection pump.
What you are getting:
1986 TD block & mechanical lifter head - this has the oil squirters which the NA motors lack
TD intake & airbox
TD exhaust manifold with T3 turbo and downpipe. I sawzalled the exhaust off after the toilet bowl flange.
TD injection pump with the LDA "needs reseal"
TD injectors & hardlines
Diesel vacuum pump
AC Compressor
Alternator
Tested good Bosch quick-glow relay
Has a set of glowplugs in it and I will toss in 4 used, "good" spares
I'm asking $450 (USD) picked up in Raleigh NC. I can arrange shipping for actual costs.
I'll put up some pictures tomorrow.
Reply #1May 26, 2009, 07:28:05 pm
Re: FS: Complete 1.6TD "core"
« Reply #1 on: May 26, 2009, 07:28:05 pm »
Reply #2May 26, 2009, 08:28:41 pm
sju
  • 32
« Reply #2 on: May 26, 2009, 08:28:41 pm »
why is there never any good deals like this on anything TD in the pacific northwest..
best of luck on the sale
80 diesel caddy
82 jetta diesel(parts car)
84 rabbit gti(daily)
89 golf gl
89 jetta (soon tobe wifes daily)
Reply #3May 27, 2009, 07:24:11 am
fdnyguy
  • 499
« Reply #3 on: May 27, 2009, 07:24:11 am »
And I drove up 95 the other day WITH my F250 Power Stroke. Figures.
Same reason I miss the lottery by 6 numbers every time..... :)
Stay safe,stay well. Jimmy.
Never forget what a "Religion of Peace" did on 9/11/01.
2015 Passat TDi. 27k
1998 Jetta 1.9TTDi 228k .
2002 F250 7.3 TD   63,000 miles. Sold.
1980 Mack CF Fire Engine. Working on it.
2007 Dodge MegaCab 5.9 Cummins. Nice, but plagued with issues
Reply #4May 28, 2009, 07:28:16 pm
« Reply #4 on: May 28, 2009, 07:28:16 pm »
Sale pending locally
Reply #5May 28, 2009, 07:33:20 pm
bigblockchev
  • 271
« Reply #5 on: May 28, 2009, 07:33:20 pm »
SJU see my post re TD engine. I am in Vancouver if you are interested. Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
