Author Topic: The all-encompassing Turbo Oil drain/feed line thread  (Read 53685 times)
Reply #30June 01, 2009, 06:16:16 am
saurkraut
  • 904
Re: The all-encompassing Turbo Oil drain/feed line thread
« Reply #30 on: June 01, 2009, 06:16:16 am »
Pulled the stock flex section off:
And, to my complete amazement, the 5/8" hose fit snugly over the ends!  They must have increased the size to 16mm.  I suppose there is no 15mm high temp hose in Europe?
Quick mock up to see how things line up:
And in goes the 5/8" fuel line.  I'll have to search for some of that braided steel stuff in 5/8" as it sits mighty close to the exhaust manifold.
The OEM hose that came off appeared to be plastic.  Teflon perhaps?
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #31June 01, 2009, 06:26:39 am
macka
  • 957
« Reply #31 on: June 01, 2009, 06:26:39 am »
Why not use a piece of header heat wrap? You still need to shield the line from the turbo, no matter what the material, and also adding a small in line oil cooler will help too.
Quote from: Vincent Walden
Reply #32June 01, 2009, 08:01:58 am
« Reply #32 on: June 01, 2009, 08:01:58 am »
Good ideas everyone, keep 'em coming.
Reply #33June 01, 2009, 02:29:54 pm
saurkraut
  • 904
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #34June 01, 2009, 03:49:47 pm
« Reply #34 on: June 01, 2009, 03:49:47 pm »
as long as his oil seals don't blow out that setup works perfect.
Reply #35June 02, 2009, 06:05:09 am
saurkraut
  • 904
« Reply #35 on: June 02, 2009, 06:05:09 am »
PTFE Hose and ferrules:
Thank you for the interest in our products.  Yes we do.  We are located in Southern California in the City of Crestline.
Regards,
Don Roy
909-338-1616
http://www.paragonperformance.com
Sent: Monday, June 01, 2009 2:33 PM
To: [email protected]
Subject: SS braided PTFE hose and ferrules
Greetings
Do you stock ferrules for swaging SS braided PTFE hose?
Where are you located?
Find somebody that has the swaging equipment and you can put it back the way it was.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #36June 02, 2009, 06:08:34 am
saurkraut
  • 904
« Reply #36 on: June 02, 2009, 06:08:34 am »
Which oil seals?
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #37June 02, 2009, 07:12:56 am
macka
  • 957
« Reply #37 on: June 02, 2009, 07:12:56 am »
Which oil seals?
are you referring to the seals in the turbo intake?
Reply #38June 12, 2009, 04:57:17 am
« Reply #38 on: June 12, 2009, 04:57:17 am »
What about feed? I need to make something and don't even know what threads/connection I need. I don't even have a stock line since this is from ground up for me on the Turbo engine.
Reply #39June 12, 2009, 05:07:00 am
arb
« Reply #39 on: June 12, 2009, 05:07:00 am »
Your local hydraulic hose shop will have everything needed to make the line…  For the supply line, I used 5/16" brake line. The fitting at the oil cooler threaded correctly to this, and the other end I used the last 7" of a stock turbo supply line and flared the end to connect to a brake flare union.
Reply #40June 12, 2009, 02:16:43 pm
« Reply #40 on: June 12, 2009, 02:16:43 pm »
That is my problem. I don't have any stock pieces from the turbo...I just have a turbo and I have to figure everything out rather quickly. I am not worried about the hose, I can run anything almost there what I am looking for is the ends. I need to know what ends to use on the flange and turbo.
Reply #41June 12, 2009, 02:20:34 pm
« Reply #41 on: June 12, 2009, 02:20:34 pm »
What turbo are you talking about? The feed on my vnt is metric but it's so close to 1/8th pipe that the brass threads aren't deformed at all. 1/8th pipe goes into the filter flange just fine to.
Reply #42June 12, 2009, 03:01:30 pm
« Reply #42 on: June 12, 2009, 03:01:30 pm »
I have a 1.6L with the KKK K24 I believe.
Reply #43June 15, 2009, 08:01:04 am
« Reply #43 on: June 15, 2009, 08:01:04 am »
Yup, I'm in the same boat with the T3.  I don't have any of the drain/feed lines so I have to make it all up myself.  :)
Reply #44June 15, 2009, 04:47:40 pm
« Reply #44 on: June 15, 2009, 04:47:40 pm »
I will make you a deal :D If I get the thing figured out first I will post my findings on here. If you do please do the same. THEN we can petition for this to be put in the faq so we don't have to do it again. I am going for the thread pitch gauges now.
Looks like the port on the feed side of the turbo is a 1.5 thread pitch...if it is metric which I am assuming. But it looks WAY bigger than 10mm which would be the standard for a 1.5, so it is either something else or a metric pipe thread???
« Last Edit: June 15, 2009, 07:14:26 pm by theman53 »
