Author Topic: Are these China GTD tips????  (Read 5831 times)
April 30, 2009, 03:29:32 pm
53 willys
« on: April 30, 2009, 03:29:32 pm »
I cant seem to find GTD tip ANY place in the USA.....my local injection shop can get stock turbo tips all day long...but no go on the DN0SD274!!
I found these on German ebay...they seem way to cheap to be real bosch??...and I can't figure out how to translate the page??
anybody have any info??
anybody have a source on nozzle tip DN0sd274?? I talked to Giles and he quoted me like $70 a tip!!! is that really my best option?!?!?!?
thanks for any help you guys have.
http://cgi.ebay.it/Einspritzduse-VW-Passat-Audi-80-90-100-DN0SD274_W0QQcmdZViewItemQQitemZ110345158818
Reply #1April 30, 2009, 07:04:27 pm
« Reply #1 on: April 30, 2009, 07:04:27 pm »
That's a damn good question.
Did you contact that guy that Duane hooked us up with? He was very reasonable on his prices.
Reply #2April 30, 2009, 07:28:46 pm
rabbid79
  • 684
« Reply #2 on: April 30, 2009, 07:28:46 pm »
Use babelfish.yahoo.com to translate.  I believe Fratelli Bosio makes some good GTD nozzles.  Something like $125 per set.
'15 WRX
Reply #3April 30, 2009, 08:19:48 pm
53 willys
« Reply #3 on: April 30, 2009, 08:19:48 pm »
Quote from: "zukgod1"
I never called him....the numbers he listed as "GTD nozzles" were not the same as the 2 numbers I have from Vince write-up.....
I emailed the Germany ebay store.....and I also found a place in the UK that has Bosch OEM DN0SD274's I emailed them and hope to hear back soon...?
Reply #4April 30, 2009, 08:20:32 pm
53 willys
« Reply #4 on: April 30, 2009, 08:20:32 pm »
Quote from: "rabbid79"
link to said nozzles??
Reply #5April 30, 2009, 08:23:49 pm
« Reply #5 on: April 30, 2009, 08:23:49 pm »
FYI, there isnt a difference in flow from the stock TD tips compared to the GTD tips.
Same thing dif part # for tracking...
Reply #6April 30, 2009, 08:37:40 pm
53 willys
« Reply #6 on: April 30, 2009, 08:37:40 pm »
what???? I was under the impression the stock turbo and stock GTD were different?
if this is the case then I will just keep my stock Turbo OEM Bosch nozzles(DNO SD273 ) I ordered today from Industrial injection...$28each??????
are you sure the spray and flow on the GTD is the same as stock turbo nozzles???
Reply #7May 01, 2009, 07:45:56 am
53 willys
« Reply #7 on: May 01, 2009, 07:45:56 am »
hey guys I found this place in the UK...gary just responded to my email....he said he can get DN0SD274 for $10.60 each USD!!! I'm about to order some today!!...and yes these are NEW OEM Bosch nozzles!!!
http://www.helptoday.co.uk/automotive/nozzles.asp?n=1
Reply #8May 01, 2009, 07:52:57 am
« Reply #8 on: May 01, 2009, 07:52:57 am »
Quote from: "53 willys"
Yes I'm sure.
The part #'s are different for tracking reasons.
Good find on the tips for $10! You better buy at least 12 so when I need a set I know where to come ;)
Reply #9May 01, 2009, 07:55:28 am
myke_w
  • 1099
« Reply #9 on: May 01, 2009, 07:55:28 am »
Not that this helps right now but - in the future I may be able to offer them, I have a supplier working on pricing right now. If there's alot of interest, I'll buy a bunch.
Reply #10May 01, 2009, 08:51:39 am
53 willys
« Reply #10 on: May 01, 2009, 08:51:39 am »
man do you think you can beat or match that price on those nozzles Myke?
I would rather support you....but I dont expect anybody can match or beat those UK prices.....why the huge price difference between what giles quoted me and the UK company??
UK GTD Nozzles=$10.60 each
Giles GTD nozzles=$70.00 each
why does everybody on the forums say the GTD's are better then the stock turbo nozzles??
why would giles even try to sell me SD274's for $70 each?? when I talked to him he made it sound like they are different?
where did you read or get your info zukgod1??
Reply #11May 01, 2009, 08:56:43 am
myke_w
  • 1099
« Reply #11 on: May 01, 2009, 08:56:43 am »
I can only guess that they either have a huge stock of NOS nozzles that they haven't updated the price on - or that they aren't OE Bosch.
I have no idea on price - I'm still looking into that.
I'd guess Giles's price is more like what I'd be able to offer, I'd guess our supplier is similar.
Reply #12May 01, 2009, 09:13:55 am
53 willys
« Reply #12 on: May 01, 2009, 09:13:55 am »
thanks for the info Myke.....
I think I'm gonna order some 274's and run those..I just called giles...he recommended the stock turbo nozzles just based on price...but he says if I can get the GTD nozzles for that cheap and they are OEM Bosch then I should do it!
he also told me he thinks they are different then the turbo nozzles on the USA diesels...the spray angle is the same..100% sure of that...but nobody according to him knows for sure the difference between theDN0SD274 and say the DN0SD293...the  "0" means 0* spray pattern.
Reply #13May 01, 2009, 09:38:08 am
« Reply #13 on: May 01, 2009, 09:38:08 am »
I had a set of OE TD tips and 2 of the "274 GTD" tips.
I had GOFF Injection in SLC flow them along with the Case tip, the 6.5 GM tips and the OE TD tips.
The 6.5, TD and GTD all flowed the same @ 76mm3 pr 1000/st.
The Case tips flowed 80 mm3 pr 1000/st.
I'm thinking the whole "GTD" thing is a mindset. "If they are GTD injectors they have to be better".
It comes down to the fact that we are injecting the fuel into a precup, There is only so much space in there for ignition in the first place so at some point we can inject too much fuel and get an incomplete burn ie; smoke. Now if we were talking direct injection like the TDi engines then the different tips are beneficial as the entire cyl and void in teh piston are used as the prechamber.
The OE TD tips are hard to beat from what I've found.
Reply #14May 01, 2009, 10:36:57 am
53 willys
« Reply #14 on: May 01, 2009, 10:36:57 am »
thanks Dan that's great info....and yes there seems to be a misconception on the whole GTD vs stock TD....
I will probably get some DN0SD274's since they are so cheap....and I wanna see if they are really oem Bosch...
plus it seems like I keep finding random places for parts all over the world..MLS from Thailand...cheap nozzles in the UK....it's kinda like a treasure hunt..lol
If I wanted the most fuel I would have kept the merc tips...but I think I can get what I want with some stock tips and a BIG 10mm or 11mm pump... :twisted:
