Author Topic: bass ackwards glow control  (Read 1861 times)
April 23, 2009, 07:02:24 am
moTthediesel
  • 194
« on: April 23, 2009, 07:02:24 am »
I wired a very simple glow control circuit for my 356TD. Just a momentary switch and a 75 amp relay I got from Summit Racing, powered by a key switched power source. I put another momentary switch along with a starter switch and a toggle in series with the key switch in the engine compartment so I can start the engine (and kill it, if needed) while working on it.
I got it running initially after a lot of cranking, as to be expected. Thing is though, it needed a lot of cranking again every time it started from cold. I was sure the glows were working because I could hear the relay click when I pushed the button, but it sure was in no hurry to start. Then, after letting the starter cool one time I forgot to hit the glow button, and it started instantly! WTF?
Well, can anyone guess what stupid thing I had done? I had grabbed a couple of 5 amp momentary switches of the rack at my local hardware store, but had not looked at them too closely   :roll:   Yeah, they were "NORMALLY CLOSED" spst switches! So, the "click" I was hearing was me shutting off the glow plugs, not turning them on -- hoo-boy!! --
Not one of my better moves, but no harm done --
'82 LandCruiser Diesel Conversion
4Cylinder 3B/KKKturbo/AudiIntercooler(gone, BNF)
'92 Dodge/Cummins D350 Getrag Dually
356 w/Quantum 1.6TD (73 mpg!)
'85 BMW 524td (Der Komisar)
'00 Jetta TDI 5spd
