Author Topic: Changing the Serpintine Belt? (AAZ)  (Read 2184 times)
April 20, 2009, 05:29:27 pm
James8485
  • 223
« on: April 20, 2009, 05:29:27 pm »
ok so my alternator finaly took a *** and i replaced the 70amp one with a 120amp one from a VR6 Corrado, everything fits, the only diff. is the pully is 6 grove and mine is 5, anyways theres an extra grove so i got everything going and woked perfect (looked straight after a few beers!!)
anywyas to make a long story short since it was just alittle off it cut my belt, like 1 grove is gone know, so now i have a 4 grove belt!!!! works fine but am replacing it this weekend i just have to swap pullies so everything aligns.
how do i change the belt? do i have to take the little pullie off at the bottom that has another belt on it>
i just need some insight on how to do it! i can get the belt for 25.00 so i dont wanna pay someone 100.00 to get it all done!
if anyone can tell me what to do i would appriciate it!!
thanks
---------James--------
Reply #1April 20, 2009, 05:36:19 pm
allsierra123
« Reply #1 on: April 20, 2009, 05:36:19 pm »
swap your pullies so you have the same amount of grooves. And you have to take the v belt off first then put a wrench on the idler pulley nut and push it back to take the tension off the serp belt. Thats all there is to it.
Reply #2April 20, 2009, 06:15:29 pm
James8485
  • 223
« Reply #2 on: April 20, 2009, 06:15:29 pm »
is there a tensioner on the v-belt? how does the v-belt come off?
i have not looked too too close at it so the above may sound dumb
i know how to get the serpintine off well not off but off the pullies so its just hangin.
is the v-belt easy to come off?
again sorry for the dumb q's
Reply #3April 20, 2009, 06:17:59 pm
James8485
  • 223
« Reply #3 on: April 20, 2009, 06:17:59 pm »
sorry for double post
can you do this all from the top? my car sits very low and cant get an arm under there and i hate having to jack up each side to do something as simple as an oil change!!
Reply #4April 20, 2009, 06:36:56 pm
allsierra123
« Reply #4 on: April 20, 2009, 06:36:56 pm »
Power steering pump slides. There is a bolt that loosens on the back of it it should slide over enough to get the V belt off.
