Author Topic: Noise on acceleration--RPM driven rumble  (Read 7475 times)
Reply #15March 27, 2009, 06:03:18 pm
clbanman
  • 705
    Cambridge, Ontario
« Reply #15 on: March 27, 2009, 06:03:18 pm »
Did this noise only start after you had the shop work on your car?  If so I would say the troubleshooting should be their responsibility.
Calvin
91 VW Golf 1.6NA 5spd
Reply #16March 27, 2009, 10:53:33 pm
DAKOTAKIDD
  • 114
« Reply #16 on: March 27, 2009, 10:53:33 pm »
yes the noise happened after the shop work was done.  This place didn't get my greatest respect and it was a cash job so they will not honor it.
The noise is a sounds like a bearing noise to me.
So if they did tighten the belt too much, is that a hard job to fix?
I will get a video tommorrow if time permits if not I will get it sunday for sure.
Reply #17March 27, 2009, 10:56:10 pm
DAKOTAKIDD
  • 114
« Reply #17 on: March 27, 2009, 10:56:10 pm »
Also, the noise could have possibly been there before ( I doubt it) it went to the shop because it went there for a really bad and noisy water pump
Reply #18March 27, 2009, 11:48:17 pm
« Reply #18 on: March 27, 2009, 11:48:17 pm »
Quote from: "Dakotakid"
Just lick your fingers and touch the center of the tensioner where the little bearing lives (behind the nut and washer).
If the moisture on your fingers and the first two layers of epidermis "vaporizes,".......then you need a new bearing in the adjuster!!!!!
best method EVER  :lol:  8)
Reply #19March 28, 2009, 01:59:29 pm
Dakotakid
  • 1240
« Reply #19 on: March 28, 2009, 01:59:29 pm »
First a few brews as an anesthetic........
Fine, you can also simply grasp the little tensioner pulley betwizt yer fingers (with engine off) and see if the little pulley has slop in it. This way has the Goodhousekeeping seal of approval.
Reply #20March 29, 2009, 07:05:46 pm
DAKOTAKIDD
  • 114
« Reply #20 on: March 29, 2009, 07:05:46 pm »
So today I started looking into it.  I checked the timing belt--it was tensioned ok--the adjusting pulley was smooth--I took the v-belts off and ran the car--revved it over--no noise!!  I put the power steering belt back on, adjusted it, ran the car and the noise reappered.  So I put a re-man power steering pump on the car and now all is well. So far the problem is solved!!
Thx guys for all you help!!
Chad
Reply #21March 29, 2009, 07:25:51 pm
« Reply #21 on: March 29, 2009, 07:25:51 pm »
Quote from: "DAKOTAKIDD"
Chad
check the boots for the steering rack for cracks.  they let dirt into the fluid and wreck the pump that way.  you might want to consider changing the pentosin stuff too.
Reply #22March 30, 2009, 08:02:33 am
DAKOTAKIDD
  • 114
« Reply #22 on: March 30, 2009, 08:02:33 am »
Quote from: "jtanguay"
Chad
What is pentosin?
