Author Topic: best oil for an aaz....  (Read 3432 times)
March 16, 2009, 12:51:18 pm
allsierra123
« on: March 16, 2009, 12:51:18 pm »
Do I need to run synthetic or is there something everyone recommends?
Reply #1March 16, 2009, 12:58:16 pm
« Reply #1 on: March 16, 2009, 12:58:16 pm »
Dello 400, Rotella 15/40
I don't see a reason to spend lots on syn unless you want to unless you want to.
These engines last 300k and up or reg oil.
Reply #2March 16, 2009, 01:49:00 pm
Golf/Jetta
  • 102
« Reply #2 on: March 16, 2009, 01:49:00 pm »
i spoil my diesel with 3 to 4 oil changes every year
15-40 if compression levels are OK (above 400)
you could go one step further 20-50 (if compression levels are below 400)
during the winter i switch to synthetic 0-40 for cold starting as it get -40oC here.
if your doing performace racing with the bling bling then synthetic 5-40
here a site all about engine oil
http://www.carbibles.com/engineoil_bible.html
'97 Jetta - 4Dr - 1.9 TiDi (Forth Car)
'94 Jetta - 4Dr - 2.0L Swaped in an AZZ - Almost done 2011 b4 Winter (Third Car)
Blue '87 Golf - 2Dr - Tags (First Car)
Red '92 Jetta (W) - 4Dr - Sold to Friend For $200 (Second Car)
Thanx For Answering My Posted Question's/Comments...
Reply #3March 16, 2009, 02:34:23 pm
« Reply #3 on: March 16, 2009, 02:34:23 pm »
lubro moly is a really good oil.  but if you're burning oil, it doesn't make much sense to put an expensive oil in... other additives such as ZDDP are pretty good too.
i've ran 5w50 in my 1.6TD for a while, and it reduced oil consumption by a lot, but i found that my power was down a little.
Reply #4March 16, 2009, 02:44:30 pm
« Reply #4 on: March 16, 2009, 02:44:30 pm »
The answer is weather-dependent, IMHO, and also subject to what you can get locally.
So, adding your location to your profile would be a help.... thanks!  :wink:
