Author Topic: Diesel Corrado  (Read 13282 times)
March 12, 2009, 03:56:12 pm
85gti
Diesel Corrado
« on: March 12, 2009, 03:56:12 pm »
Anyone on here do one yet?
I have a line on a g60 that had an engine fire, and I just so happen to have a 1.9TD freshly tuned up that would look great under the bonnet.  Anyone done this yet?
Reply #1March 12, 2009, 03:59:23 pm
allsierra123
Diesel Corrado
« Reply #1 on: March 12, 2009, 03:59:23 pm »
:shock:  im not sure that the gearing would work for it. I have never seen one done though. Although the G60 is a rare car that could be why.
Reply #2March 12, 2009, 04:36:55 pm
Diesel Corrado
« Reply #2 on: March 12, 2009, 04:36:55 pm »
stick a TDI transmission under the hood with that 1.9TD and you'll be happy.  the gearing will give you good economy, and make the engine perform closer to its torque range which will give very good performance.
Reply #3March 12, 2009, 04:38:46 pm
g-spec
  • 289
Diesel Corrado
« Reply #3 on: March 12, 2009, 04:38:46 pm »
There is one guy in the states that put a tdi into a corrado, he actually has done two swaps like that. You could google that....and there was a guy that just posted a 1.9TD corrado with an engine fire, his GP harness caught on fire. It is definatly doable.
Reply #4March 12, 2009, 04:40:40 pm
Diesel Corrado
« Reply #4 on: March 12, 2009, 04:40:40 pm »
yea everything just bolts right in apparently.  the glow plug system requires moderate electrical skills, and that is probably the hardest thing to hook up.
Reply #5March 12, 2009, 05:02:24 pm
85gti
Diesel Corrado
« Reply #5 on: March 12, 2009, 05:02:24 pm »
Nice!  I know evrything is possible I just wanted to know what problems I may run into.  Diesels are an easy swap from what I have done/seen.  That was half the reason I want to go that route.  I plan on using a cable shift tranny and my k-frame/a arms from my mk2. Wiring is pretty simple, it was easy putting a td in my buddies 91 jetta that was originally gas so this should be pretty similar.  I will post up again next week when I get the G60 out and see what kind of a mess the fire made.  Thanks guys.   :twisted:
Reply #6March 12, 2009, 05:20:21 pm
88jetta350
Diesel Corrado
« Reply #6 on: March 12, 2009, 05:20:21 pm »
Sounds like a cool project, and it would definitely have it's advantages over the 2 stock corrado engines.
More reliable than the G60 engine.
MUCH more fuel efficient than a VR6
and ALOT cheaper/easier to repair than both.
Reply #7March 12, 2009, 09:14:56 pm
dieselwagen
  • 85
Diesel Corrado
« Reply #7 on: March 12, 2009, 09:14:56 pm »
someone on vortex have put a 1.9 diesel in a corrado.
he can probly hook you up with details on his build,
i just can't remember the dudes username right now
1986 golf 1.6
Reply #8March 12, 2009, 10:28:25 pm
Richmond69er
  • 15
Diesel Corrado
« Reply #8 on: March 12, 2009, 10:28:25 pm »
The guy on the 'tex that put a 1.9td into a rado...his name is Arkam he lives in deltan BC.
I'm not sure what his username on the tex is but he is on www.dubberz.com his username is "armodude83" he posts in the diesel tech forum you can message him on there and he will be more then happy to help you out.
He LOVES his diesel rado!
Cheers,
Justin
Reply #9March 13, 2009, 02:19:52 am
stewardc
Diesel Corrado
« Reply #9 on: March 13, 2009, 02:19:52 am »
There's a guy here in Nova Scotia just finishing a super TDI swap into a Rado...lotsa chrome. Here's the link;
http://www.customobsessions.com/modules.php?name=Forums&file=viewtopic&t=17946
Reply #10March 13, 2009, 05:16:16 am
Ziptar
  • 565
Diesel Corrado
« Reply #10 on: March 13, 2009, 05:16:16 am »
On old thread on this forum of a Corrado TDI swap,
http://www.vwdiesel.net/phpBB/viewtopic.php?t=11174
pictures are gone though...  :(
Reply #11March 13, 2009, 05:35:05 am
arb
Re: Diesel Corrado
« Reply #11 on: March 13, 2009, 05:35:05 am »
Quote from: "85gti"
You can do anything you want if you put enough time and skills into it. I've been putting a 1.6 NA into a 92' Dodge Caravan, upgrading to turbo, with a Chevy alternator since last summer. Almost ready for first start.
Reply #12March 13, 2009, 06:43:50 am
g-spec
  • 289
Diesel Corrado
« Reply #12 on: March 13, 2009, 06:43:50 am »
The mounting points for both engines the TD and the g60 are the same. If you use a passat td or a tdi tranny (o2a) it will work. I would check out someone's build thread first just to see what is involved.
Reply #13March 13, 2009, 07:21:06 am
85gti
Diesel Corrado
« Reply #13 on: March 13, 2009, 07:21:06 am »
Quote from: "stewardc"
Dale, I know Dan is doing a TDI but I am not quite into that realm of diesel yet.  I am going to stay mechanical for now, I just wanted to see some Rado diesel threads!  I have no intentions of going with a G60 or VR6 as it will be my main vehicle for the summer months.
Justin, thanks for the info.  I am going to try and track him down to see what he thinks of the swap.
Thanks to everyone else for the kind words and as soon as I get this thing stripped you will be the first to see that another VW will be burning dinosaur bones!!   :twisted:
Reply #14March 13, 2009, 10:02:13 am
blackdogvan
  • 574
Diesel Corrado
« Reply #14 on: March 13, 2009, 10:02:13 am »
I thought Oldschoolrich was putting a 1z m-tdi in his corrado.?
He seems to have dropped of the face for the earth tho...
1991 Vanagon 1.9 mTDI
