Need a CE2 speedo wiring plug out of a MK2 jetta/golf/whatever... i just swapped in a gauge cluster out of a 92 jetta that matches my trans and actually reads correctly. it would be sweet if i could find one relatively close..
Do you need the wiring harness that goes from the cluster to the fuse box? I have one if you want it, make me offer.
all i need is the pig tail and about 4 inches of wire for the gauge cluster. i did a cluster swap from a newer jetta into my rabbit. and the plugs are NOT EVEN CLOSE to the same.
20 dalla. You come get now!
