So a pretty simple job in other words?
Good luck, be sure to post and let us know how you make out. FYI... keeping an eye on your progress in the infopop biodiesel forums... your tank looks great, what are you using to heat the vegoil?Jake
Quote from: "rackley"So a pretty simple job in other words?Unless the factory joints are still there, in which they are usually held in with rivits.... ask me how I know. If you need new nuts and bolts, I can find the size, beats paying techtonics for their "ball joint bolt kit".Brendan84 Scirocco 8v00 Camaro L36 M49
You might want to have the front end aligned as well. I tried to set my ball joints back in where they were before but they were still out of alignment. Just keep an eye on your tires for wear. My new ball joints came with new bolts. Of course this is for a 91 Jetta
