helo. at start sorry for my english...
i have 1.6td engine in my golf mk1. i have done timing advance mode and gov mode.
i have installed turbo vnt20 with N70 and electriccontrol used mpx.
i have exhaust from 1.5 diesel original from my auto but i want to change it...
intercooler i have from bmw 2.5tds.
what can i do to make my 1.6td 1V faster?
i change rings on pistons and I can do something else with my engine before i put it in car.
how to make down side of engine more powerfull. you know crankshaft?
Can i put more powerfull injectors ? From what car ( my have 155bar)
SB have 160...
Hi and welcome to the board.
Don't worry about your English... already I can tell you speak it better than most of us! ;-)
I'd recommend you start by reading thru the
FAQ ... it's got tons of good information and will answer at least some of your initial questions. In particular look for a section called "Make your car faster" down a ways.
Once you're up to speed on the basics you're in a good spot to ask questions about the details.
Again, welcome aboard !!
I would suggest you add your location in Poland and then do a search for a member named:
zaprzal
He is also from Poland and should be able to help you out.
Good luck,
zaprzal's profile page, hope that helps!
