Author Topic: TD trans ID ??  (Read 2640 times)
March 08, 2009, 08:28:57 pm
arb
TD trans ID ??
« on: March 08, 2009, 08:28:57 pm »
Can anyone ID this trans for me? It was a consolation purchase for driving 600 km north into Ontario to purchase an 83' TD rabbit that did not exist...
Here is no "FF" or "020" markings that I can see. I was going to rebuilt this trans and powder coat the case for my Caravan TD conversion :-)
Here it is right side up.... you can see the speedo cable -cut- so it should be 87' or later - right ??
its a rabbit manual trans I think :-D
Reply #1March 08, 2009, 08:33:59 pm
cyrus #1
  • 360
TD trans ID ??
« Reply #1 on: March 08, 2009, 08:33:59 pm »
I'd bet that it's a 4S. The 4S is 5th from the top. :D
http://scirocco.org/gears
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #2March 08, 2009, 08:38:37 pm
arb
TD trans ID ??
« Reply #2 on: March 08, 2009, 08:38:37 pm »
Yes ? Where to you see the 4S ? I thought the ID was always on the bottom of the bellhousing :-)
NOW I see it... those 16 hours of driving has affected my eyes ;-)
Reply #3March 08, 2009, 08:54:48 pm
TD trans ID ??
« Reply #3 on: March 08, 2009, 08:54:48 pm »
when did you drive 600km's for a rabbit that didn't exist?  that totally sucks!
btw the spreadsheet i'm looking at is showing 2H, 4K, 7A, & FK as being from '83 rabbits.  if indeed that is the vehicle this transmission came from... and maybe there are a few more combinations of transmissions that i haven't listed...
for your sake, i hope its the 7A as it has the 0.71 5th  8) 2700 rpm @ 65mph, or even lower if you upsize the wheels  :wink:
BUT, what i can deduce from the photo, is that it is a 4S transmission (listed for '87 & '88 jetta's)
Final          1st            2nd           3rd           4th           5th
3.94   3.45   1.94   1.29   0.91   0.75
Reply #4March 09, 2009, 02:39:32 am
1outof5
Re: TD trans ID ??
« Reply #4 on: March 09, 2009, 02:39:32 am »
Quote from: "arb"
yes that one is a 4S and it wasn't last mounted in a MK1. It still has the MK2 gearbox rear mount
Reply #5March 09, 2009, 08:02:27 am
blacknoise
  • 12
TD trans ID ??
« Reply #5 on: March 09, 2009, 08:02:27 am »
The R&P is pretty close to that of a mkI but not right on so you're speedometer/odometer will be off just a little.  The gear spread on this box is nice with the tallest 4th gear you can get on a mkII.  The 3.94 diesel R&P is the only bummer, really.  I have a 4s in my Rabbit 1.9TD and it is really nice for all the hill climbing I do in my commute- I remain in top gear climbing crazy hills but on the highway the engine is at about 2825RPM at 65mph w/ nominal tires.
The taller mkII gasser R&P combined with the mkII .75 top gear gives the same reduction as the .71 top in a mkI box w/ 3.89R&P if you follow.
-B
81 Rabbit TD - AAZ adaption NEED INJECTORS
90 Jetta D - "tall" tranny (code ACN)
86 Golf TDI (building) - 1900rpm@65mph, .205 nozzles, kp39A turbo, H2O IC
