Author Topic: Lift pump needed?  (Read 2079 times)
March 06, 2009, 12:27:55 am
allsierra123
Lift pump needed?
« on: March 06, 2009, 12:27:55 am »
Im am doing the fuel lines tomorrow on my gas to diesel aaz conversion. Its a 91 vanagon. I took out the stock fuel pump But what Im wondering is will the IP be enough to pull the fuel from the vanagon tank or will I need a small low pressure lift pump?
Reply #1March 06, 2009, 04:47:54 am
arb
Lift pump needed?
« Reply #1 on: March 06, 2009, 04:47:54 am »
as long as you prime the lines, no life pump is needed. The injection pump has a strong pump.
Reply #2March 06, 2009, 06:48:12 am
Lift pump needed?
« Reply #2 on: March 06, 2009, 06:48:12 am »
adding a small lift pump wouldn't be a bad idea, as long as it was 5 psi or so.  if everything is running as it should, it won't really make much difference.
Reply #3March 06, 2009, 06:54:18 am
arb
Lift pump needed?
« Reply #3 on: March 06, 2009, 06:54:18 am »
Quote from: "jtanguay"
That's what I did on my diesel install to my dodge caravan. My pump allows free flow through it w/o running. I have an AUX switch to power it - like when I change the fuel filter.
Reply #4March 06, 2009, 10:02:06 am
Lift pump needed?
« Reply #4 on: March 06, 2009, 10:02:06 am »
ive got a cheap little electric fuel pump for a lift pump. and honestly i can say that my car has more power with the lift pump. and the best thing of all.. i never lose my prime to my pump. just turn the key on, and wait a few seconds. it fills the pump up fast.
