S O L D
by
stewardc
on 27 Feb, 2009 04:39
This kit allows you to preset two boost settings for your car. Toggle between stock boost and a high performance setting using the included Boostvalve boost controller. Easy way to limit your boost and save fuel, yet with a flip of a switch have max boost power. Includes high quality compact industrial 12V pneumatic switching solenoid, Boostvalve boost controller and all necessary hoses, fittings clamps and instructions.
Custom application ideas: Solenoid may be activated by an RPM activated switch, wide-open throttle switch, 1st gear micro-switch or whatever(not included).
$100 OBO
#1
by
stewardc
on 27 Feb, 2009 15:08
Bump
#2
by
stewardc
on 01 Mar, 2009 04:05
Bump.....
#3
by
stewardc
on 02 Mar, 2009 15:09
bump again.....
#4
by
stewardc
on 03 Mar, 2009 04:24
Bump --- brand new. Even has the installation instructions.
#5
by
stewardc
on 04 Mar, 2009 02:57
Bump
#6
by
dillenger1
on 04 Mar, 2009 04:40
how can you have max performance without going in and adjusting the pump when you switch for hi-po?seems you would need something to adjust the pump because you r still gonna be injecting(20psi)worth of fuel when your your not at 20psi.
#7
by
stewardc
on 04 Mar, 2009 11:37
That's what the LDA does automatically.
#8
by
dillenger1
on 04 Mar, 2009 14:31
Yah but you wont get say 30psi when you flip the switch from running 10psi.If your running 30psi then at 10psi your smoking,
#9
by
stewardc
on 05 Mar, 2009 05:22
My properly setup Giles pump doesn't smoke at 9 psi, and smokes just a little at 26 psi. As I said, the LDA adjusts fueling dependant upon boost.
#10
by
dillenger1
on 05 Mar, 2009 16:07
Im thinking of full load smoke i guess.Seems on my setup that i cant hit 20psi without more fuel.i do have a 10mm head though.
#11
by
on 05 Mar, 2009 17:02
you need to tweak your LDA. it is definitely possible to get the pump to deliver enough fuel for 20+ psi and not smoke.
#12
by
nighthippie
on 11 Mar, 2009 18:07
would it work for a 2000 tdi?
#13
by
stewardc
on 11 Mar, 2009 18:12
Sold...thanks !
