Author Topic: what manifolds will fit a 1.6 n/a diesel?  (Read 6504 times)
February 25, 2009, 03:27:30 am
lzmdzsem
  • 5
« on: February 25, 2009, 03:27:30 am »
i'm looking at doing a 1.6 n/a diesel to TD upgrade some time in the semi-near future and am wondering what manifolds are compatible? and how does a gasser manifold compare to a diesel manifold in a TD application?
'82 VW Jetta N/A diesel ~140,000 miles
Reply #1February 25, 2009, 03:55:58 am
Turbinepowered
  • 1206
« Reply #1 on: February 25, 2009, 03:55:58 am »
As far as bolting up, any 8v VW manifold will bolt to the 1.6 head. There is ostensibly some benefit to running a gasser manifold on a turbodiesel, as it decreases the air bias across the cylinders that's inherent in the stock 1.6TD intake design.
16v+ manifolds won't bolt up, as their port spacing is different.
Reply #2February 25, 2009, 03:44:21 pm
AdAm84
« Reply #2 on: February 25, 2009, 03:44:21 pm »
Any manifold from an 8V non-crossflow will work. Intake manifolds from 8V cross flows like the ABA or AEG will not work as they are to the front of the head like the 16V.
Reply #3February 26, 2009, 06:42:24 am
BellCityDubber
  • 251
« Reply #3 on: February 26, 2009, 06:42:24 am »
in order to run the intake manifolds on the TD's dontcha hafata flip the turbo and manifold down so there's enough clearance?
Reply #4March 05, 2009, 08:42:12 am
« Reply #4 on: March 05, 2009, 08:42:12 am »
Quote from: "BellCityDubber"
I'd heard that somewhere too, haven't managed to sort it out yet.  Anyone?
Reply #5March 05, 2009, 08:45:01 am
truckinwagen
  • 1895
« Reply #5 on: March 05, 2009, 08:45:01 am »
yes you do, I am using a stock gasser mani, and the turbo needs to be flipped and then clocked so the oil feed and drain point in the right direction.
83 Opel Kadett Diesel
Reply #6March 05, 2009, 08:49:59 am
« Reply #6 on: March 05, 2009, 08:49:59 am »
Got any pictures?
Reply #7March 05, 2009, 08:59:22 am
truckinwagen
  • 1895
« Reply #7 on: March 05, 2009, 08:59:22 am »
not yet, the manifolds are not yet mounted, but I will have plenty of pics after this weekend.
Reply #8March 05, 2009, 09:56:35 am
« Reply #8 on: March 05, 2009, 09:56:35 am »
ive got a gasser mani on my car. works wonders. best torque gain from any one single mod.. and ive got a VNT 17 off an 01 ALH engine. it makes scary amounts of boost really quick. it starts making boost under 1500rpms. i had to do some modifying to one of the mounting bosses on the bottom of the intake tho, but you might be able to get around that with an mk1 gas mani. im not sure if they have that mount or not. and i just fabbed up my own custom adaptor to go where the throttle body would be. best part is, if my turbo ever goes tits up, and doesnt take the engine with it, take the air cleaner off the turbo intake and clamp it on the intake mani adaptor to limp home.
Reply #9March 05, 2009, 01:46:09 pm
subsonic
  • 1836
« Reply #9 on: March 05, 2009, 01:46:09 pm »
Which 17 are you running, the a or b?  Are you running it with mechanical control?  Is this on your 1.5 from the signiture?
Reply #10March 05, 2009, 08:59:01 pm
« Reply #10 on: March 05, 2009, 08:59:01 pm »
im pretty sure its just a 17a.. and it has no vane control. it works well with the vanes wide open. and yep, its on the 1.5 in my 81.
