Author Topic: Cummins fuel filter - QuickTD looking to you for this.  (Read 4585 times)
Reply #15February 24, 2009, 10:40:47 am
« Reply #15 on: February 24, 2009, 10:40:47 am »
If you have a PnP around ya, the mk2 gassers had a in-tank pump that works great. It's low pressure like around 4-5 psi and gets up good.
They use the low pressure pump to feed the high pressure pump mounted where our water separators are.
53willys just finished a gasser conversion and left his in-tank pump in place.
We discovered when we did the first start up that you cant suck fuel though that pump, not even a little. It has to be running to get fuel through it.
Reply #16February 24, 2009, 10:54:12 am
g-spec
  • 289
« Reply #16 on: February 24, 2009, 10:54:12 am »
I was also looking into the golf 3 with a ACC engine (1.8 8v fuel injected carb) the pump is rated at 1.2BAR = 17 psi. Thats a little too much but I was thinking of running a pressure regulator to set it at 5lbs. But if you say that the mkII pumps run at 4-5lbs I should be able to get one. Is there a way I can test it to see what pressure it runs at before I install it in the car???
Reply #17February 24, 2009, 11:23:24 pm
AudiVWguy
« Reply #17 on: February 24, 2009, 11:23:24 pm »
Try looking up " Facet " fuel pumps on Ebay. They work very well. I think you can also buy them at NAPA.
Reply #18February 26, 2009, 12:44:48 pm
arb
« Reply #18 on: February 26, 2009, 12:44:48 pm »
Quote from: "zukgod1"
I wished I could have done that with my Caravan diesel conversion, but mine was a high pressure for the fuel injection.
Here's a pump for $32:
http://www.jcwhitney.com/EMPI-ELECTRONIC-FUEL-PUMPS/GP_2011022_N_111+20004560+600002062_10101.jcw
If you first search for "diesel pump" they will offer you a $10 discount, so with shipping you'r looking at something like $26 in your hands. Its the pump I have on my Dodge Caravan conversion.
