Author Topic: cylinder sleeves  (Read 2150 times)
February 18, 2009, 07:14:45 pm
thomcat
  • 20
cylinder sleeves
« on: February 18, 2009, 07:14:45 pm »
Do they affect durability in a 1.6 na ( with maybe a turbo added later)
Reply #1February 18, 2009, 10:39:08 pm
cylinder sleeves
« Reply #1 on: February 18, 2009, 10:39:08 pm »
yea it's actually quite the process... the block has to be machined to accept the sleeve, and then heated up, while the sleeve is super cooled.  that way it will be a really tight fit.  i think that is how they do a 'dry liner'.  the wet liner process involves using o-rings and from reading on the site, seems that attention to detail during the whole process is the key to success.
i think its best that you consult a machineshop local to you and ask if they've linered engines, and the results, and of course the price.  in some areas, this route might actually be cheaper than locating a motor that doesn't already need a rebuild.
the best part about going the liner route, would be re-using the old pistons if they're in good shape.
the liners themselves are reasonably cheap if you buy from the www.dieselvw.com site.
Reply #2February 19, 2009, 02:57:44 am
thomcat
  • 20
needs a 1.5 mm over bore
« Reply #2 on: February 19, 2009, 02:57:44 am »
I had a severly burned piston resulting in enough scoring to require a .060(1.5mm) over bore  .  I couldnt find a listing for pistons that large, so sleeving one cylinder  may be my best and only option. most junk yards I frequent have crushed thier import section in recent months.
Reply #3February 19, 2009, 06:32:15 am
arb
cylinder sleeves
« Reply #3 on: February 19, 2009, 06:32:15 am »
some industrial diesel engines are made with wet sleeves from the factory. Easy to keep them running for years if you can change a sleeve as easiliy as changing a pistion.
http://findarticles.com/p/articles/mi_hb4310/is_200109/ai_n15027021
