Author Topic: glowplugs needed?  (Read 7671 times)
February 16, 2009, 03:01:39 pm
dillenger1
  • 777
glowplugs needed?
« on: February 16, 2009, 03:01:39 pm »
How cold can you guys get them to start without the plugs?Im wondering about my compression now.I cant even get a cough after some fast cranking w/ 1000amp battery without glowplugs.My dads cummins will start without the grid in like 35-40f.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #1February 16, 2009, 03:05:21 pm
truckinwagen
  • 1895
glowplugs needed?
« Reply #1 on: February 16, 2009, 03:05:21 pm »
I have never been able to start without the plugs when the engine is cold, even after a rebuild I needed a few seconds of glow plug to get it to start in the summer time.
83 Opel Kadett Diesel
Reply #2February 16, 2009, 03:36:00 pm
glowplugs needed?
« Reply #2 on: February 16, 2009, 03:36:00 pm »
Indirect injection diesel engines, like ours, have very different cold starting habits than their direct injection cousins, like the Cummins and VW's TDI designs.
Reply #3February 16, 2009, 03:58:29 pm
  • 1739
glowplugs needed?
« Reply #3 on: February 16, 2009, 03:58:29 pm »
Pretty hard even in summer, almost impossible when winter comes.
Reply #4February 16, 2009, 05:35:21 pm
Dakotakid
  • 1240
glowplugs needed?
« Reply #4 on: February 16, 2009, 05:35:21 pm »
The same as above, Ben. Maybe in super hot weather....but, not otherwise.
Reply #5February 16, 2009, 05:44:25 pm
Re: glowplugs needed?
« Reply #5 on: February 16, 2009, 05:44:25 pm »
Quote from: "dillenger1"
unless your compression is 500+ psi, you won't be able to cold start it.  its in the design of the swirl chamber.  the the swirl chamber has to be a certain temperature to properly ignite the diesel, and that is why the glow plug is necessary.  higher compression numbers will help elevate the air temps though, maybe enough to start the car below 0 deg C.
cummins motors, while being direct injection, also have intake air heaters (maybe not all models) which greatly enhance the cold starting/cold running.  i'm personally a fan of the intake heater system, but it will draw quite a bit of juice from the electrical system...
Reply #6February 16, 2009, 09:23:17 pm
AudiVWguy
glowplugs needed?
« Reply #6 on: February 16, 2009, 09:23:17 pm »
Okay, about the hot air theory. Say you have a heat gun, blow some hot air into the intake for a couple of minutes. Engine should start right up. (try to not melt anything)
Disclaimer:
-some assembly required
-your milage may vary
-don't eat yellow snow
-nine out of the ten voices in my
head told me to stay home and
clean my guns today
Reply #7February 16, 2009, 10:47:39 pm
glowplugs needed?
« Reply #7 on: February 16, 2009, 10:47:39 pm »
Quote from: "AudiVWguy"
Disclaimer:
clean my guns today
getting the glow plugs to work would be far less hassle for the long term  :lol:
Reply #8February 17, 2009, 02:34:08 am
  • 3468
    • McScrubbins Body Wash
glowplugs needed?
« Reply #8 on: February 17, 2009, 02:34:08 am »
yeh my new build will start, angrily, without glow plugs only when it's above 0. I tried 1 cold start WITH glow plugs and i knew it would not have started without them. You can almost always roll start though.
Reply #9February 17, 2009, 02:42:27 am
Turbinepowered
  • 1206
glowplugs needed?
« Reply #9 on: February 17, 2009, 02:42:27 am »
Quote from: "Smokey Eddy"
You cannot, however, roll-start a Volvo 240 diesel. Ask me how I know.  :roll:
Reply #10February 17, 2009, 05:20:43 am
AudiVWguy
glowplugs needed?
« Reply #10 on: February 17, 2009, 05:20:43 am »
Okay, how do you know?
Reply #11February 17, 2009, 11:40:18 am
Turbinepowered
  • 1206
glowplugs needed?
« Reply #11 on: February 17, 2009, 11:40:18 am »
Because we attempted to do so when I was much more diesel-stupid. It wouldn't start, bad plugs and a cold NC spring morning, and we pushed it down a small hill. Still no start... and we had to push it back up the hill!  :x
Volvo diesel sedans are heavy, dagnabbit!
Reply #12February 17, 2009, 11:51:43 am
glowplugs needed?
« Reply #12 on: February 17, 2009, 11:51:43 am »
Quote from: "Turbinepowered"
in that situation... bust out the brake parts cleaner!!!  :lol:
Reply #13February 17, 2009, 12:14:25 pm
  • 1739
glowplugs needed?
« Reply #13 on: February 17, 2009, 12:14:25 pm »
"Volvo diesel sedans are heavy, dagnabbit!"
You got that right. I had one last spring that had broken the cam. With an automatic. With a 60 liter WVO tank [of course it was full] . My shop had enough of slope that it took 6 of us to push it into the shop. Even on a level surface it 2 of us could barely move it.
Reply #14March 21, 2009, 11:07:36 am
glowplugs needed?
« Reply #14 on: March 21, 2009, 11:07:36 am »
Quote from: "jtanguay"
brake parts cleaner? for what? starting your engine? or?
