Author Topic: eco to td conversion  (Read 2813 times)
February 05, 2009, 06:48:48 am
swapmeat
  • 3
« on: February 05, 2009, 06:48:48 am »
is the i/p top the only difference between the eco and a reg t/d?i.e. i could swap pumps and everything else is the same or...swap tops from another pump? are internals,turbos,everything else the same?thanks i'm kinda new and need more power in my caddy.got a good price on a full eco swap but want to make sure o the differences. :lol:
Reply #1February 05, 2009, 06:55:57 am
rallydiesel
  • 1880
« Reply #1 on: February 05, 2009, 06:55:57 am »
The pump has a smaller rotor head. The turbo is smaller but spools quicker and is better for stop and go city driving in some people's opinion. I think there are other differences too like gear ratios, presence of a catalytic converter, etc. But basically the same.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2February 12, 2009, 10:27:37 am
allsierra123
« Reply #2 on: February 12, 2009, 10:27:37 am »
Is timing it after the swap all that difficult?
Reply #3February 12, 2009, 11:12:26 am
« Reply #3 on: February 12, 2009, 11:12:26 am »
timing it after swapping the pump? no different then timing it after a belt change :)
hoowever you put the pumo on it doesn't matter what position it sits in. as long as all the rest is timed correctly (cam, crank both at TDC) then timing the pump will be exactly the same.. rotate backwards with guage in until it stops, zero guage, then return the engine to TDC, and move the pump to get the desired timing you desire :lol:
goodluck.
Reply #4February 16, 2009, 01:24:10 pm
Gutta Perka
  • 6
« Reply #4 on: February 16, 2009, 01:24:10 pm »
I have a Golf -92 ECO TD
Putting a LDA-pump on it and connect that to the turbo - will that destroy the function of the catalytic converter?
Here in Sweden we have to test our cars each year for emissions.
/Gutta
Reply #5February 16, 2009, 01:38:54 pm
Gutta Perka
  • 6
« Reply #5 on: February 16, 2009, 01:38:54 pm »
Quote from: "libbybapa"
Yes, it will most likely plug the cat.
Andrew
... "most likely" ... hmm... sounds a bit uncertain to me.
No other mods - also with anything else being factoryset?
/Gutta
Reply #6February 17, 2009, 08:11:15 am
ilikevwdiesel
  • 1202
« Reply #6 on: February 17, 2009, 08:11:15 am »
eco diesel jettas sold in the US had an AVX code transmission with a 4.25 to 1 ring and pinion ratio. They really buzz at 65 mph. Find an ACH or AGS trans to replace it and sell the AVX to a racer. You'll probably profit off the deal.
My Bio
Reply #7February 17, 2009, 11:16:39 am
TurboJ
  • 661
« Reply #7 on: February 17, 2009, 11:16:39 am »
Quote from: "Gutta Perka"
/Gutta
Fit a de-cat pipe and then put the cat back on when it's time for the yearly inspection. After inspection, take the cat out once more...
That's how we do it in Finland  8)
Jetta II 1.6 TD 'Project 200'
Reply #8February 18, 2009, 04:37:32 am
Gutta Perka
  • 6
« Reply #8 on: February 18, 2009, 04:37:32 am »
Of cause!
Viva Finland! :twisted:
/Gutta
Sweden
