Author Topic: AAZ swap questions  (Read 4312 times)
January 23, 2009, 02:54:57 pm
ObscuredByClouds
  • 98
AAZ swap questions
« on: January 23, 2009, 02:54:57 pm »
What would happen if you bought a complete aaz longblock with all accessories and put it into a 1.6td mk2 platform. Good right? Simple simple wiring corrections?
Now how about the turbo. I want 170hp with a k24/k26 hybrid, AAZ, and minimal pump mods. Does the AAZ pump have fuel enrichment? Is it an 8 or 9mm head?
What clutches and transmissions need to be considered..
Reply #1January 23, 2009, 05:10:07 pm
Dirtrag2
  • 298
AAZ swap questions
« Reply #1 on: January 23, 2009, 05:10:07 pm »
every thing is prety much plug and play, search for AAZ in mk2 and you should find some results.
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #2January 26, 2009, 01:31:02 pm
dokarex
  • 61
AAZ swap questions
« Reply #2 on: January 26, 2009, 01:31:02 pm »
Far as I know from searching this site what you do to a 1.6 TD you can do to a 1.9TD
1987 1.9TD Doka from Germany gasser DU tranny, fuel turned up, 1.6 LDA pin, boost at 15 psi,egt and boost gauges,stock diesel tach,air filter behind passenger tail light, IC to come
2005 Jetta Wagen TDI
B6200 Kubota Diesel
16ft Freestyle catermeran
16ft Sunray 85HP
Reply #3January 26, 2009, 05:04:13 pm
1slowvw
AAZ swap questions
« Reply #3 on: January 26, 2009, 05:04:13 pm »
Any 020 will bolt right up transmission wise, so you can re-use the tranny from your 1.6.
Pumps are very very similar and tuning them fuel wise is pretty much the same(once you pilfer the pin from your 1.6 pump).
As for wiring every AZZ swap I've done I have ripped off the AZZ wiring loom and used all the 1.6 wiring.
Clutch whise you might want to ugrade to a 16v pressure plate and make sure your disc is good, I personally went through a pair of stock clutches on my AZZ last summer at 20psi and strong fueling, so an upgrade would be suggested with the power you're looking to make. I am going 6 puck and heavy duty pressure plate but thats overkill.
All in all your looking at the easiest motor swap out there, so just take your time and make sure everything is tight and have fun.
1SlowVW
Reply #4January 27, 2009, 04:33:25 am
Torchd
  • 372
AAZ swap questions
« Reply #4 on: January 27, 2009, 04:33:25 am »
I am going to do the same... 1.9TD in MKII golf with giles pump and gtd nozzles.
I have bought an act 4 puck clutch kit which says not suitable for street use. I didn't think much when I ordered it and now i'm having second thoughts. Is it going to be reallly bad?
