yeah that is wierd, our detroit always fires right up but it is a sorry excuse for a diesel! no power
With 2/3's of my rad covered and a fast idle(hand throttle), my engine is up to at least 160 after 10 min of idling. I hate driving with the windshield freezing up on the inside, and have a poor defrost, so it idles every morning.
You should wait for the oil light to go out before revving the engine and you should drive gently until it is up to normal operating temperature. It is significantly worse for the engine to idle it's way to normal operating temp than it is for it to be placed under gentle load to get there. BEST for any engine, gas or diesel, even in mild climates, is to install a block heater and use it pre-heat the engine year round to eliminate all cold starts.Andrew
I also agree that these diesels use very little fuel at idle whch should translate to a slow warm-up. But on the other hand, if they use less fuel at idle then why will the temps climb in the summer in stop and go traffic and the engine fan come on. You would think just the idling alone would bring it down but it doesn't work that way and this engine uses a 180 thermostat and never runs over 1/3 of the scale on the guage no matter how fast you go in the Summer. Block and head were cooked as well as the radiator and the rest of the cooling system works perfect as well and operates perfectly normal as far as I'm concerned. But since we started talking about less fuel at idle and all it's got me thinking now which sometimes is not the best thing for me to do :lol:
