I'm going to go with let the turbo see oil and then go. So depending on how cold it is (the viscosity of the oil, if you're running synthetic i guess it doesn't matter...) would determine how long to wait. I would not start the car up, go inside, wait 10 minutes and then go because YES efficient engines take forever to get hot because they are burning so little fuel.Diesels are renown for burning such a small amount of fuel on idle.
Quote from: "Smokey Eddy"I'm going to go with let the turbo see oil and then go. So depending on how cold it is (the viscosity of the oil, if you're running synthetic i guess it doesn't matter...) would determine how long to wait. I would not start the car up, go inside, wait 10 minutes and then go because YES efficient engines take forever to get hot because they are burning so little fuel.Diesels are renown for burning such a small amount of fuel on idle.Boy that's sure the truth, I just started my new 1/6 T//D on the hoist with a cooling system with about a quart and a half of fuel in a big coffee can to feed and return lines and after probably 12 minuets or so running it mostly idle and quick blips it looks like the can is just about where it was when I first started, my leaf blower uses more than that :lol:
well dang, I use a block heater but still let it idle for 5-10 min because I've got a 10 month old and want the car to be as warm as possible - but I noticed that it took for ever to warm up and wondered if it was worth it. Guess i'll quit wasting fuel and just go, warms up quicker that way anyway!and i'm in Rexburg Idaho, 0-20 degrees for the past few months.
It somewhat depends on whether you have to let it warm up before it will move to....My VW will take off, with pretty good power, with only 30 seconds idling. It's good to give at least that much just to get the oil flowing everywhere. My Mitsubishi has no power if cold started (especially at below freezing) till it's warmed up for a few minutes at least -- so you Can't drive it even if you wanted to -- letting the clutch out will just stall it.I have no idea why the two of them behave so differently...Z
