Fixmyvw.com
Author Topic: Please help; mtdi won't start  (Read 3958 times)
January 17, 2009, 11:11:17 pm
chiefdiesel
  • 31
« on: January 17, 2009, 11:11:17 pm »
While adjusting the fuel screw with  the engine running, I touched the fuel shut off solenoid switch and stalled the engine.  I have replace the solenoid switch on the ip, replaced the glow plug relay, and the ignition switch.  Still it will not start.  The glow plugs do not have power, also no power before and after the fuse link.  Terminal #50 on the ignition switch do not have power.  Any suggestions are greatly appreciated. Tommy.
2 B4 Passats Ecodes/HID/pp764/rc2
'85 Jetta coupe 1.6 n/a
'80 Caddy 110 (afn) m-tdi/12mm Lt 2.8 ip/.216/fmic
Reply #1January 17, 2009, 11:32:55 pm
cyrus #1
  • 360
« Reply #1 on: January 17, 2009, 11:32:55 pm »
What do you mean you "touched the fuel shut off solenoid"?  Did it get shorted out?  That wire is not fused...  :x
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #2January 17, 2009, 11:45:37 pm
Rabbit TD
  • 840
Re: Please help; mtdi won't start
« Reply #2 on: January 17, 2009, 11:45:37 pm »
Quote from: "chiefdiesel"
You should be able to get it started with a jumper wire from plus side of the battery to the fuel solenoid and a heavy one to the glow plugs and remove the glow plug one when it starts so you can at least drive it till the troubleshooting is done.  It sure souds like a fuse somewhre to me though if it happened when you touched the solenoid but I don't know how it's wired though.  You'll eventualy find it :wink:
Reply #3January 18, 2009, 12:27:09 am
chiefdiesel
  • 31
« Reply #3 on: January 18, 2009, 12:27:09 am »
Pull starts don't work,  When the wrench touched the top of the screw on the solenoid, the engine shutoff, and will not start. I used a jumper wire on the solenoid and the #4 glowplug and nothing.  There i no current anywhere in the glowplug system.
Reply #4January 18, 2009, 01:17:39 am
« Reply #4 on: January 18, 2009, 01:17:39 am »
put a direct wire from the battey to the solenoid.  should work.  just a temporary option until you can diagnose the electrical issue.  doesn't sound like fun...
Reply #5January 18, 2009, 10:16:42 am
« Reply #5 on: January 18, 2009, 10:16:42 am »
What one of your cars is this for?
Reply #6January 18, 2009, 12:00:27 pm
chiefdiesel
  • 31
« Reply #6 on: January 18, 2009, 12:00:27 pm »
This for the Caddy, I swapped in the mtdi from the Jetta last summer.  The engine code is afn  with a 2.8 lt 12mm ip...the nozzles are .216, fmic.  Only the turbo has not been upgraded.
Reply #7January 18, 2009, 01:07:21 pm
« Reply #7 on: January 18, 2009, 01:07:21 pm »
Are any of the other electrical connections working?
Reply #8January 18, 2009, 06:36:30 pm
  • 1739
« Reply #8 on: January 18, 2009, 06:36:30 pm »
"50" from the ignition switch is the starter signal. voltage out of the switch while cranking. What you need to look for is the "15" circuit. That is the one that has voltage at all times, cranking and running. It is not impossible you cooked something in the fuse box. However if you have an american made rabbit, there are 3 or 4 american style fusable links below and behind the battery. I don't have the wiring diagrams in front of me to check. With the ignition on, do you have 12 v at the solenoid valve? If not you gotta dig out a diagram and figure exactly where that signal comes from.
Reply #9January 18, 2009, 07:53:47 pm
chiefdiesel
  • 31
« Reply #9 on: January 18, 2009, 07:53:47 pm »
Finally got the engine running.  It needed a fresh battery and I jumped the solenoid switch and the glow plug harness.  Why does it only start with the solenoid switch jumped?
Reply #10January 20, 2009, 01:50:17 am
Rabbit TD
  • 840
« Reply #10 on: January 20, 2009, 01:50:17 am »
Because you bypassed the bad part and I still say it's a fuse or a fusible link or relay like they said, You're just eleminating most of the system and you can drive it forever like that if you want to put up with all the wire yanking  :(
Reply #11January 20, 2009, 01:48:40 pm
« Reply #11 on: January 20, 2009, 01:48:40 pm »
Quote from: "the caveman"
I believe it is the 30 series that has power all the time, and 15 is only when the key is in the run position.
I'd venture to guess that your glowplug relay is dead. If you have a spare try it out. First, check to see if you have power to the solenoid with the key in the run position and also in the start position. Disconnect the starter when doing the check to save battery life
Reply #12January 21, 2009, 06:42:53 am
chiefdiesel
  • 31
« Reply #12 on: January 21, 2009, 06:42:53 am »
I'll test those circuits today, thanks.
