Author Topic: crank  (Read 2442 times)
January 17, 2009, 05:26:27 pm
96jetta
crank
« on: January 17, 2009, 05:26:27 pm »
what is the torque speck for the pulley bolt? and can it slip?
Reply #1January 17, 2009, 07:34:55 pm
Rabbit TD
  • 840
Re: crank
« Reply #1 on: January 17, 2009, 07:34:55 pm »
Quote from: "96jetta"
I've just used my 425 lb. impact gun on max. with  blue loctite for years and everythig has been fine and a whole lot easier.
Reply #2January 17, 2009, 08:04:57 pm
96jetta
crank
« Reply #2 on: January 17, 2009, 08:04:57 pm »
so its a big number then lol  :lol:
Reply #3January 17, 2009, 08:12:06 pm
Rabbit TD
  • 840
crank
« Reply #3 on: January 17, 2009, 08:12:06 pm »
I forget what it actualy is but the gun makes it a whole lot easier taking the bolt out too, axel nuts too which I seem to end up doing quite often for one thing or another, different transmissions and such :D
Reply #4January 17, 2009, 08:20:15 pm
96jetta
crank
« Reply #4 on: January 17, 2009, 08:20:15 pm »
well you have to change it up every now and again lol 8)
Reply #5January 17, 2009, 09:43:10 pm
Rabbit TD
  • 840
crank
« Reply #5 on: January 17, 2009, 09:43:10 pm »
I've got a 110 volt 1/2 inch gun also that I got from Harbor Freight, I think it's rated 250 lbs and the are only $49 now, I saw one the other day there.  It comes in handy especialy if you have a generator {which luckily I do} and you can take anything apart on these cars with it that's sitting in a field or a junk yard all rusted to hell and such wth a little PB Blaster or the equivelant on axel nuts it's especially nice.  I've used it also on the crank nut with the blue loctite with no problems but I usualy use the bigger air gun on it, never had anything come loose so far :wink:
Reply #6January 18, 2009, 05:34:51 pm
Sam Johnson
  • 55
crank
« Reply #6 on: January 18, 2009, 05:34:51 pm »
96Jetta
According to the manual the torque spec for the crank bolt is 66 ft-lbs + an additional 90 degrees of turn.  Yes, it is a big number.
As I have a wobble in my PS pulley I am going to take all the pulleys off and see what is the problem.  For certain I will replace my crank bolt with the updated one.   In fact, last week I bought this at the VW dealer for around $4.00--it was a surprise to me that the dealer in Tucson actually had it in stock.   I am also planning on replacing the crank toothed belt pulley.  Of course, once I take it off if the crank nose is damaged seriously it will be time for Plan B.
The question I have is what method or methods do people use to lock the crank so that they can remove the bolt as well as to reinstall the bolt?   Is there a special tool that can be purchased or one that people fabricate?
Thanks for any suggestions or advice as I am putting off doing this but know it needs to be done before the gear skips a tooth on the timing belt.
Sam
Tucson, AZ
Reply #7January 18, 2009, 06:15:36 pm
cyrus #1
  • 360
crank
« Reply #7 on: January 18, 2009, 06:15:36 pm »
Quote from: "Sam Johnson"
Here is the one that I built.  It's just a 4' piece of angle iron that has the matching bolt pattern to the crank sprocket.  Thanks to Libbybapa for the idea on this one.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #8January 18, 2009, 07:30:39 pm
96jetta
crank
« Reply #8 on: January 18, 2009, 07:30:39 pm »
i put the tranny in 5th gear and tightend it down but the motor is still un the car. i havent done it on a motor stand
