Author Topic: Puff of smoke upon start up. Any clues?  (Read 4594 times)
January 11, 2009, 06:40:22 pm
TijuanaTom
  • 19
« on: January 11, 2009, 06:40:22 pm »
I noticed this weekend when I start my 1981 rabbit diesel pickup that a puff of smoke comes out upon starting her...   It goes away immediately but I wonder what might be the cause..  Also should I be concerned?
Many thanks.
TT
Reply #1January 12, 2009, 04:46:04 am
« Reply #1 on: January 12, 2009, 04:46:04 am »
If it's black then that is 100% normal
Reply #2January 12, 2009, 06:20:10 am
spencebm
  • 686
« Reply #2 on: January 12, 2009, 06:20:10 am »
haha, best post evar!!
Ben Spencer
Reply #3January 12, 2009, 02:35:05 pm
dillenger1
  • 777
« Reply #3 on: January 12, 2009, 02:35:05 pm »
haha...at startup the pump is allowed max fuel momentarily before the flywheel starts to spin,which then acts on the idle spring.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #4January 12, 2009, 03:37:34 pm
  • 1739
« Reply #4 on: January 12, 2009, 03:37:34 pm »
You may have one glow plug burnt. how cold is it where you are?
Reply #5January 12, 2009, 06:00:04 pm
TijuanaTom
  • 19
« Reply #5 on: January 12, 2009, 06:00:04 pm »
Sorry for the novice question guys..  Its my fist Diesel and I'm learning..
Yes, black smoke... Like a magician making the rabbit disappear.. and its not cold at all where I live..   Maybe down to the 40's ?
Thanks again!
Reply #6January 12, 2009, 08:22:07 pm
Rabbit TD
  • 840
« Reply #6 on: January 12, 2009, 08:22:07 pm »
Quote from: "TijuanaTom"
Thanks again!
It sounds like you have a pretty good engine if that's all the smoke you get and then goes right away, that is what we all hope to achieve.  Don't feel bad about asking though, we're all learning all the time.  I've learned so much about these things since I've been here I'm soon gonna need a bigger brain to keep it all in :lol:
Reply #7January 12, 2009, 08:59:45 pm
cyrus #1
  • 360
« Reply #7 on: January 12, 2009, 08:59:45 pm »
Quote from: "Rabbit TD"
Unfortunately it doesn't work quite like that.  Other stuff (usually important) gets pushed out instead.  :lol:
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #8January 13, 2009, 04:43:07 am
« Reply #8 on: January 13, 2009, 04:43:07 am »
Quote from: "cyrus #1"
It usually starts with significant other's birthday's and anniverseries... useless stuff like thatc :P
If your whole car is being covered in smoke then you have a problem. It should just be a small puff and instantly go away
Reply #9January 13, 2009, 09:54:50 pm
Rabbit TD
  • 840
« Reply #9 on: January 13, 2009, 09:54:50 pm »
Well that explains what has been going on, man it's just like DisneyLand in there now, hope it stays that way for a while :lol:
