General Information
Troubleshooting
How to diagnose fuel problems
Topic: How to diagnose fuel problems (Read 5714 times)
January 06, 2009, 05:56:12 am
zozie
January 06, 2009, 05:56:12 am »
Well my mk1 1.6D n/a did it again.
I know I have a small fuel leak so I think that's what's causing the headache. When the temp dips to about -10, the car will start and run fine, then in 5 minutes it will loose power and die. I use additives and keep my tank full for the most part. I happened before and as I drive it it improves but this morning I just left it alone. It was surprising cause I drove it yesterday and filled it up. (it's my everyday driver with about 120kms/day for work and drinks about 4.8l/100)
Could ice in the fuel be caused by my minor leak on the tank? I'm just wondering because I guess the fuel expands as it warms up, then as it shrinks when I leave it alone it may suck moisture in, which then gets frozen.
What u think?
January 06, 2009, 07:10:05 am
January 06, 2009, 07:10:05 am »
I would think that if the leak was your problem then it would be between the tank and filter. My thinking is that there is enough fuel in the IP, line between it and the filter and in the filter. If i were you replace the filter. What happens when it is cold is that, again there's enough in the line and pump, but because the filter is old, it has trapped water and is now frozen. So the car starts with what is after it but then runs dry. Also use some WINTER fuel conditioner to slow down waxing.
January 07, 2009, 12:45:40 am
January 07, 2009, 12:45:40 am »
Do you have clear fuel lines?
If you do; can you see air bubbles in the fuel?
A vacuum gauge connected to the fuel line will let you know when the pump is working hard to get fuel,.. due to a fuel line restriction.
January 07, 2009, 01:46:48 am
January 07, 2009, 01:46:48 am »
How often does one change the fuel lines?
my return line has cracks in it but doesn't seem to be weathered...
Where do the bubbles tend to originate? from a not quite so full filter?
Can that plastic nob on the top (inline of the return) leak air into the filter sending bubles through the feed line?
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
January 08, 2009, 12:57:33 am
January 08, 2009, 12:57:33 am »
I like clear lines to and from the pump,
and change them when they get brittle or unclear.
January 08, 2009, 04:54:42 am
January 08, 2009, 04:54:42 am »
It could be your water seperator
January 08, 2009, 11:14:55 am
zozie
January 08, 2009, 11:14:55 am »
Well I changed the filter and it got cured. There is no water seperator on the tank of the MK1.
January 08, 2009, 05:40:24 pm
Tony2ltr
January 08, 2009, 05:40:24 pm »
What is the proper material for the clear fuel lines to and from the IP?
HOw about for the injector return lines?
Is there a good source for these?
-Tony
92 Jetta Ecodzl/biodzl/WVO/meth-H2O turbspray
1969 Subaru 360 Sambar (converted to Electric)
1975 Chevy Cosworth Vega Turboed
1991 Toyota Pickup (megasquirted)
2004 POS Honda Civic (I'll never buy another)
2 cylinder Lister Petter diesel CO-Gen unit
January 08, 2009, 11:02:58 pm
January 08, 2009, 11:02:58 pm »
I like urethane from motorcycle shops.
Comes in a lovely clear blue,.. and I think other colors.
January 09, 2009, 07:32:05 am
Tony2ltr
January 09, 2009, 07:32:05 am »
Is this like the yellow stuff that you get for small engine repair, chain saws and the like?
-Tony
January 09, 2009, 07:45:49 am
January 09, 2009, 07:45:49 am »
Quote from: "zozie"
So i guess i was right
Reply #11
January 09, 2009, 04:43:13 pm
Tony2ltr
Reply #11 on:
January 09, 2009, 04:43:13 pm »
I started my rebuilt 1.6 ecodiesel (NA block) for the first time today. I had a lot of air bubbles in the line, so bad that there was no return fuel, and it eventually died. I bypassed the water separator, and it helped (the fittings were all very rusty), but there are still a lot of air bubbles in the line! I wonder if the fittings on the top of the tank are sucking air?
-Tony
Reply #12
January 09, 2009, 09:29:42 pm
Reply #12 on:
January 09, 2009, 09:29:42 pm »
Yes I think the chainsaw shops sell urethane fuel line too,... that is not blue. I think the orange stuff at Ace hardware is urethane too.
Check the screen on the fuel pickup in the tank. It might be clogged.
Have a vacuum cleaner ready to clean up all the crap that accumulates around the sender, before you open the tank.
Reply #13
January 10, 2009, 01:40:25 pm
Tony2ltr
Reply #13 on:
January 10, 2009, 01:40:25 pm »
Well, I got it going today. The stupid fuel filters that they use for that era diesels (with the plastic banjo) was sucking air in. I replaced it with an older style, and just returned the fuel to the tank, and no problem, no more bubbles in the supply hose. I had some problems getting my air cleaner box hose back on the car because the turbo that I used (early 80's) has a bigger inlet on the compressor. the air cleaner box hose would not go on it anymore, so I had to steal a reducer coupling from the turbo plumbling on my Cosworth Vega. I turned the fuel screw on the IP up about 1/2 turn, and now I have a lot more power, but the blowoff valve (also from the early 80's engine) is limiting the boost to 15 PSI.
now the brakes need some work, and I need some new tires(and rims), but I am very excited about the new engine, so far it runs great!
Can I access the pickup in the tank through the hole in the trunk floor?
-Tony
Reply #14
January 10, 2009, 01:40:44 pm
Tony2ltr
Reply #14 on:
January 10, 2009, 01:40:44 pm »
-Tony
General Information
Troubleshooting
