Author Topic: larger plunger/head assembly  (Read 23381 times)
Reply #30August 27, 2006, 01:53:37 pm
hillfolk'r
  • 1532
« Reply #30 on: August 27, 2006, 01:53:37 pm »
i can turn mine down so it doesnt smoke (12mm)
Throttle cables ftw
Reply #31January 10, 2008, 01:37:09 pm
rallydiesel
  • 1880
« Reply #31 on: January 10, 2008, 01:37:09 pm »
So are all larger pump heads from TDI's? If you are running a 1.6 IDI, you have to stay with a 1.6 or 1.9 IDI camplate, right?
If I were to hypothetically convert my 1.6 IDI into a 1.6 TDI and keep my 1.6TD pump, would going to a TDI rotor and camplate be all that was needed to run TDI injectors?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #32January 10, 2008, 02:20:39 pm
Tintin
  • 1279
« Reply #32 on: January 10, 2008, 02:20:39 pm »
Can import what engine you convert into a TDI engine, you absolutely need a M-TDI pump, the 1.6TD pump does not work on a 1.6 hypothetic TDI, euhh.. that work, but with very poor power and a lot of smoke, bad idle etc.....
Reply #33January 10, 2008, 03:02:06 pm
rallydiesel
  • 1880
« Reply #33 on: January 10, 2008, 03:02:06 pm »
So a tdi camplate and 10mm tdi pump head wouldn't work on a 1.6TD pump?
Reply #34January 10, 2008, 03:04:58 pm
Tintin
  • 1279
« Reply #34 on: January 10, 2008, 03:04:58 pm »
with some matching parts, yes.
Reply #35January 10, 2008, 03:06:11 pm
« Reply #35 on: January 10, 2008, 03:06:11 pm »
Tintin means the stock TD pump won't work unmodified. You would need a TDI head, cam plate and I think a different or modified control lever and a modified governor wouldn't hurt either.
Reply #36January 10, 2008, 03:16:05 pm
rallydiesel
  • 1880
« Reply #36 on: January 10, 2008, 03:16:05 pm »
Awesome. Here's another general question:
Is there any real difference between a TDI pump head and an IDI pump head besides TDI's having a larger range of plunger sizes?
Reply #37January 10, 2008, 04:11:35 pm
« Reply #37 on: January 10, 2008, 04:11:35 pm »
I think the plunger foot is different except maybe on some AAZ pumps.
Reply #38January 11, 2008, 04:07:50 pm
Tintin
  • 1279
« Reply #38 on: January 11, 2008, 04:07:50 pm »
The bigger foot plunger has been standard at bosch for a few years, the older pump have a small foot plunger and small drive pin.
I found in an old european pump for some application with 11 or 12mm, the plunger foot are small but with a bigger came plate drive pin, if I try to put this plunger in a came plate with small drive pin, that fit but It's tight, I think that the old cummins pump here, are similar.
Reply #39January 11, 2008, 06:03:06 pm
rallydiesel
  • 1880
« Reply #39 on: January 11, 2008, 06:03:06 pm »
What sort of mods for the accelerator lever are required? You mean like changing the angle of the levers for the max fuel adjust and the governor lever?
Reply #40April 03, 2008, 12:07:40 am
« Reply #40 on: April 03, 2008, 12:07:40 am »
Isn't turning the fuel down sort of the same as picking your foot off the go pedal a little?
