Author Topic: Stud to replace the crank bolt?  (Read 9391 times)
Reply #15December 09, 2008, 02:44:25 pm
« Reply #15 on: December 09, 2008, 02:44:25 pm »
Quote from: "truckinwagen"
I will jump on this later today!
so both the crank and camshaft bolts are 14x1.5?
if so I will buy two and go for both!
the camshaft bolt is listed as M12X1,5X35SW18 not sure what the SW18 means though... it also says hexagon head bolt (combi)
now the camshaft bolt isn't as critical in this case, so the stock one should do... but the crankshaft stud idea is where its at  8)
Reply #16December 09, 2008, 02:47:25 pm
truckinwagen
  • 1895
« Reply #16 on: December 09, 2008, 02:47:25 pm »
just thinking, if they were the same I might as well do both, I like dealing with stud/nut way better than bolts anyway, especially when they locate the part like the crank and cam do.
I will go ahead and buy one of these studs then and shove it on the motor!
thank for the idea and the source!
83 Opel Kadett Diesel
Reply #17December 09, 2008, 09:10:38 pm
AudiVWguy
« Reply #17 on: December 09, 2008, 09:10:38 pm »
SO...........what kind of nut and washer are ya gonna use?
Reply #18December 10, 2008, 02:38:56 am
« Reply #18 on: December 10, 2008, 02:38:56 am »
Quote from: "AudiVWguy"
yea we haven't fully decided on that.. yet.. but i do believe applying some moly lube might be a good idea to get some more torque applied.
can anyone comment on that? what is the max the nut should be torqued at??? what can a 14mm stud handle???
thanks
Reply #19December 10, 2008, 08:31:05 am
« Reply #19 on: December 10, 2008, 08:31:05 am »
From what I've seen, most M14x1.5 wheel studs are AT LEAST 8.8, which calls for 90 ft-lbs of assembly torque.  Most of the motorsport ones for VW are 10.9 or 12.9, although Bildon does not list the hardness on the ones they sell, I have seen similar ones at those hardness levels.  Assembly torque for 10.9 is 133 ft-lbs, and 12.9 is 145 ft-lbs.
Reply #20December 10, 2008, 10:16:16 am
« Reply #20 on: December 10, 2008, 10:16:16 am »
does anyone know a formula to calculate the clamping force PSI using thread pitch, etc?
Reply #21December 10, 2008, 06:49:50 pm
cyrus #1
  • 360
« Reply #21 on: December 10, 2008, 06:49:50 pm »
I can find out a formula that will work... My brother is a mechanical engineering student. 8)  We will need to know the tensile strength of the material though.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #22December 11, 2008, 03:08:44 am
clbanman
  • 705
    Cambridge, Ontario
Calvin
91 VW Golf 1.6NA 5spd
Reply #23December 11, 2008, 03:48:46 am
« Reply #23 on: December 11, 2008, 03:48:46 am »
14mm to inch = 0.551181102
Fastener Major Diameter (in.)
=0.55
Torque (in - lbs) Applied
=110.2
Axial "Clamp" Force (lbs)
=1000
Reply #24December 17, 2008, 03:54:17 pm
vwt4
  • 107
Re: Stud to replace the crank bolt?
« Reply #24 on: December 17, 2008, 03:54:17 pm »
Quote from: "jtanguay"
Just a thought...  you could get wayyy more clamping force with less actual torque required that way.  i guess the problem is finding a place that sells something that big?
thoughts?
This is a very, very GOOD idea  :D
I am seriously thinking about adding it before bolting my new crank pulley back up (and repaired crank).
has anyone done it yet? pics!
Reply #25December 17, 2008, 05:05:13 pm
truckinwagen
  • 1895
« Reply #25 on: December 17, 2008, 05:05:13 pm »
well, I was going to do it, but as I was trying to figure out my fuel problem my timing slipped and I bent a few valves which means that all of my projects are on hold until after I get my head rebuild AGAIN.
it really sucks pouring this much money and time into something I haven't been able to drive in six months.
oh well, it gives me an excuse to port the head as it will have to come off anyway.
Reply #26December 17, 2008, 05:15:42 pm
« Reply #26 on: December 17, 2008, 05:15:42 pm »
i sent an e-mail to ARP but didn't get a response as of yet... i might try raceware as i'm sure they have 14mm studs out there with the right thread pitch on the one end, and the nice and low thread pitch (more clamping force) on the nut end.
Reply #27December 18, 2008, 07:45:50 am
« Reply #27 on: December 18, 2008, 07:45:50 am »
I had much better luck calling ARP, E mail can be ignored I think.
