Author Topic: Stud to replace the crank bolt?  (Read 9426 times)
December 07, 2008, 09:05:46 am
« on: December 07, 2008, 09:05:46 am »
Just a thought...  you could get wayyy more clamping force with less actual torque required that way.  i guess the problem is finding a place that sells something that big?
thoughts?
Reply #1December 07, 2008, 06:22:22 pm
« Reply #1 on: December 07, 2008, 06:22:22 pm »
nobody???  virtually eliminate crank failures here!!!  :lol: or is that just an absurd idea?
Reply #2December 07, 2008, 06:58:44 pm
truckinwagen
  • 1895
« Reply #2 on: December 07, 2008, 06:58:44 pm »
not an absurd idea at all, if you can find a stud that would fit.
go forth and find one!
83 Opel Kadett Diesel
Reply #3December 07, 2008, 09:17:43 pm
« Reply #3 on: December 07, 2008, 09:17:43 pm »
what about those guys getting head studs from fastener companies? they must be able to supply something to suit!!!
the main reason for my inquiry is because i'm assembling my motor (1.9 1Z TDI) and the crank bolt isn't that cheap (considering it has to be replaced everytime its taken off, as well as the substantially high torque required to properly tighten it.
just taking a guess here, but with a special moly lube, 70-80 ft/lbs should be good enough (and actually produce MORE clamping force than the stock bolt torqued at nearly double, if not more), and that is sooo easy to achieve (no fancy tools needed-just hook up the tranny and put it in gear)
my initial thoughts on problems with this idea are that removing the pulley(s) with the stud installed would be quite difficult... therefore a solution would be required; by cutting a slot into the end of the stud, or having a hex style nut shape ground in, so that a normal socket could fit on-space permitting of course.   this 'extra' step of removing the stud shouldn't be that bad.  a good few 'taps' would help loosen it up.
maybe the TDI crank fix wouldn't be necessary on a vehicle using a stud type fastener on the crank pulley???   :D
thanks
Reply #4December 08, 2008, 02:51:15 am
« Reply #4 on: December 08, 2008, 02:51:15 am »
maybe even a stud to replace the camshaft pulley bolt too?  virtually eliminate he possibility of it slipping, without over tightening?  :wink:
Reply #5December 08, 2008, 06:52:06 am
« Reply #5 on: December 08, 2008, 06:52:06 am »
I like your thinking.
I would be willing to bet ARP has something already you could use. Give them a call with the dims/ thread pitch etc.
Reply #6December 08, 2008, 08:29:16 am
AudiVWguy
« Reply #6 on: December 08, 2008, 08:29:16 am »
Why don't you call ARP?
Reply #7December 08, 2008, 12:35:15 pm
« Reply #7 on: December 08, 2008, 12:35:15 pm »
i'll contact them, but off chance does anyone have the proper dimensions/thread pitch for the crank bolt & camshaft pulley bolt???  if not i suppose i could go out and measure.
thanks
Reply #8December 08, 2008, 01:01:31 pm
« Reply #8 on: December 08, 2008, 01:01:31 pm »
It's an M14x1.5x47 I think.  Very hard to find studs in that size.  It just so happens that there are wheel studs made to screw in to VW hubs to replace the bolts that are M14x1.5x50, but they are double-ended.  Might be worth a try though.  I think they were grade 8.8.
Reply #9December 08, 2008, 05:29:22 pm
cyrus #1
  • 360
« Reply #9 on: December 08, 2008, 05:29:22 pm »
You could probably also use a long set screw.  It would then have the socket head.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #10December 08, 2008, 09:00:15 pm
AudiVWguy
« Reply #10 on: December 08, 2008, 09:00:15 pm »
Check this out.
http://www.bildon.com/catalog/DetailsList.cfm?ID=M14.DE.Stud&Nav=10&SubNav=none
Imagine what kind of torque this baby can take!  :shock:
Reply #11December 09, 2008, 01:11:37 am
« Reply #11 on: December 09, 2008, 01:11:37 am »
Quote from: "AudiVWguy"
Check this out.
hmmm very interesting!!! i was hoping to find a stud with a low thread pitch to increase the clamping force, but this seems like it would be perfect!
Reply #12December 09, 2008, 08:51:22 am
truckinwagen
  • 1895
« Reply #12 on: December 09, 2008, 08:51:22 am »
good find!
so have we agreed that both bolts are 14x1.5?
I just want to make sure before I go and buy something.
Reply #13December 09, 2008, 12:45:23 pm
« Reply #13 on: December 09, 2008, 12:45:23 pm »
Quote from: "truckinwagen"
good find!
well if brendan is right...  :wink:
considering that race guys torque their wheel nuts down to more than 150 ft/lbs, i think the crank pulley would be going NOWHERE if cranked down to that (especially with some moly lube)
actually i just opened etka and its saying M14X1,5X33 (1.6's at M14X1,5X33) so i think we're in business  :twisted:  just need someone crazy enough to try this!!!  :lol: i think i might...
Reply #14December 09, 2008, 01:28:26 pm
truckinwagen
  • 1895
« Reply #14 on: December 09, 2008, 01:28:26 pm »
I will jump on this later today!
so both the crank and camshaft bolts are 14x1.5?
if so I will buy two and go for both!
