Author Topic: Yanked 1.5 injectors  (Read 5510 times)
Reply #15December 09, 2008, 07:25:03 am
« Reply #15 on: December 09, 2008, 07:25:03 am »
That's what I did, it's not as accurate as the method laid out in the Bentley but hey..
I cleaned the top of the pistons really well then used a machinist straight edge across th top of the pistons at 12, 2, 4, 6, 8, 10. I suspect that was a tad overkill but I wanted to make sure as I was using feeler gauges.
Reply #16December 10, 2008, 12:29:44 pm
Typrus
  • 93
« Reply #16 on: December 10, 2008, 12:29:44 pm »
I'll have to do that.
Anyones opinions on injectors or nozzles? Stick with 1.5'ers and go with 1.5'er nozzles? The nozzles are $7 a pop, so cheap. Injectors I can't imagine are worn beyond shimming or the likes.
Also, my buddy is convinced the cam is a bit worn down (I think he's comparing to the ALH he has sitting in his shop) so how can we be sure? I want to be able to find out so I can either set him at ease or eat my own foot. lol.
Any suggestions for "honing" the pistons and rings? Use a bottle-brush honer or a stone-set? What to do with the rings? We'll definitely replace all 4 sets if we find any broken ones (from the ether run away perhaps?) And we'll take a peek at the bearings. I just don't want to futz with plastigaging and all that. But if we find it need a bore or bearings we'll likely get the block boiled and the head shot. It'll turn into a full-on rebuild lol.
Still haven't taken the time to peruse the IP rebuild thread. Might print it off and read it at work. lol. Not a fan of the Zone. Oh well though.
Eventually we'll have Giles take care of our little IP as well. Might go find a 1.6TD and get it built and just keep the aneroid off till we decide to go turbo or not.
1995 Toyota Camry 2.2L 5-speed
1984 Toyota Tercel 4wd Wagon 1986 "           "           "      "
1996 VW Passat TDI 1Z w/ KermaTDI Stage 3 kit
1999.5 F-250 7.3L Powerstroke
2002 Excursion 7.3L Powerstroke (Dads)
Reply #17December 10, 2008, 01:38:45 pm
« Reply #17 on: December 10, 2008, 01:38:45 pm »
Quote from: "Typrus"
i'm pretty sure that the TDI cam is a bit more abrupt, but not 100% sure.
