Author Topic: 1.9 tdi block heater  (Read 5299 times)
November 18, 2008, 11:23:26 pm
madrogers
  • 165
« on: November 18, 2008, 11:23:26 pm »
My 2000 Jetta has this pissy 300 watt heater glued to the oil pan, does any one up north have a bettey solution for a block heater? seams the engineers did not want to put a frost plug hole in the block to accomadate a coolant heater like 95% of the other cars sold.
Thanks Mark.
PS. still working on my glow plug problem.
83 CADDY 1.6 TD WINTER
83 CADDY 1.9 AAZ SUMMER
Reply #1November 19, 2008, 05:28:06 am
fairweather
  • 85
    • TDI Syncro
« Reply #1 on: November 19, 2008, 05:28:06 am »
This isn't a freeze plug heater but it gets good reviews, one is in my future.
http://www.frostheater.com/
83 Caddy with CY code 1.6TD out of a rabbit.
Reply #2November 19, 2008, 06:16:18 am
passatdiesel
  • 19
« Reply #2 on: November 19, 2008, 06:16:18 am »
I run a similar system on my PassaTDI that I bought at canadian tire. I bought the 1500 watt version and plugged in for 45 min the coolant temp reaches the 2nd bar, instant cabin heat! The system taps into the oil cooler lines and naturally circulates. The unit I have does not have a check valve built in.
Reply #3November 23, 2008, 04:42:27 pm
Typrus
  • 93
« Reply #3 on: November 23, 2008, 04:42:27 pm »
Have a Frost Heater in our 96 Passat 1Z... Works GREAT. Tight fit though.... Lol, actually 2nd one to install the 1Z Passat kit. Biggest problem I had was snapping off a mounting ear and having to metal zip tie it in. lol. But it works great and is pretty subtle.
1995 Toyota Camry 2.2L 5-speed
1984 Toyota Tercel 4wd Wagon 1986 "           "           "      "
1996 VW Passat TDI 1Z w/ KermaTDI Stage 3 kit
1999.5 F-250 7.3L Powerstroke
2002 Excursion 7.3L Powerstroke (Dads)
