Author Topic: 1966 Volvo Wagon with a VW 1.6 diesel & Toyota 5-speed  (Read 6218 times)
November 05, 2008, 09:14:26 pm
mfritch
  • 11
    • http://www.loghomz.com
« on: November 05, 2008, 09:14:26 pm »
I now have all the parts that I need to start putting the diesel in my Volvo.  I purchased a 1990 Jetta with a 1.6 diesel for the donor car.  The person that I bought the car from had a turbo and exhaust manifold in the trunk.  He said that it was possible to upgrade the NA engine to a turbo.  Is this true?  If so, are there some websites that address how to do the job?  I could use any input that you might offer.
I'm also curious about what rpm would be best for crusing at 60 mph.  I currently have 26.0" tall tires, 4.56:1 rearend and the fifth gear in the W59 is a .85 ratio.  right now it looks like I will be turning 3185 rpm at 60 mph.  Are there any recommendations?
Mark Fritch
Everything I own is diesel!
Current project - 1966 Volvo 122 wagon with a VW 1.6 diesel and a Toyota 5-speed.  I'm putting on Wilwood four wheel disc brakes and a power rack and pinion.
Reply #1November 05, 2008, 09:38:19 pm
« Reply #1 on: November 05, 2008, 09:38:19 pm »
those rpm's are a bit high if you want to get the good mileage (in a turbo app.)
yes you can put a turbo on an N/A motor just the way it is, but you need to put the turbo intake on as well.  the only problem is exhaust gases.
http://www.dieselvw.com/EGTGauge.htm thats a cheaper gauge, but nobody has commented on the responsiveness of this gauge... has anyone bought one???
http://www.aircraftspruce.com/catalog/inpages/westfaa_egtcht.php
i forget which one was recommended, but these are quick reacting, and very good quality!  jake on this site gave it a very good review!  it was about $80 for both the probe & gauge.  their gauges aren't pretty, but they do the job!
now the N/A pump will need to be turned up most likely to provide boost, and you won't have any boost enrichment.  for this you need to either buy a turbo pump, or the turbo pump head.  spearco made a turbo kit though, and it had a boost enrichment device that screwed into the max fuel screw.  quite ingenious, and could easily be re-constructed by someone with the right skill  :wink:
now if you installed a small K03 or VNT turbo, you wouldn't need the boost enrichment device, as the turbo would spool very quickly and give you the boost to burn the extra fuel.  OR you could simply increase the fuel, but wait till the turbo gets going before you mash the pedal  :wink: (keeping your EGT's below 1300-1400F)
Reply #2November 11, 2008, 06:36:46 am
arb
« Reply #2 on: November 11, 2008, 06:36:46 am »
Got some photos of your project ? Photobucket.com is an easy way to post them into your vwdiesel blog :-)
I'm always eager to see how people are using one of the best diesel engines I've laid hands on.
How are you adapting the engine to the toyota trans ? Why toyota and not the VW Fox trans ? Because you have the toyota ?
Reply #3November 11, 2008, 06:58:21 am
MJF
  • 581
« Reply #3 on: November 11, 2008, 06:58:21 am »
Quote from: "arb"
I thought Fox is FWD :wink:
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #4November 11, 2008, 07:42:17 am
arb
« Reply #4 on: November 11, 2008, 07:42:17 am »
Yeah, I should have said Audi
Reply #5November 11, 2008, 09:08:17 am
arb
« Reply #5 on: November 11, 2008, 09:08:17 am »
Quote from: "libbybapa"
What Audi trans is rear wheel drive?
Andrew
There are guys who used the Audi Quato trans for a rear wheel drive. They use it in 2wd mode and don't connect the front drive shaft.
Reply #6November 12, 2008, 03:17:41 am
dillenger1
  • 777
« Reply #6 on: November 12, 2008, 03:17:41 am »
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #7November 12, 2008, 03:18:10 am
dillenger1
  • 777
« Reply #7 on: November 12, 2008, 03:18:10 am »
Reply #8November 12, 2008, 03:18:26 am
dillenger1
  • 777
« Reply #8 on: November 12, 2008, 03:18:26 am »
Reply #9November 12, 2008, 07:12:42 am
« Reply #9 on: November 12, 2008, 07:12:42 am »
Holly triple post Batman!!!!
Reply #10November 12, 2008, 03:49:17 pm
dillenger1
  • 777
« Reply #10 on: November 12, 2008, 03:49:17 pm »
triple the goodness!
Reply #11November 25, 2008, 09:55:39 pm
carpart
  • 1
« Reply #11 on: November 25, 2008, 09:55:39 pm »
Any progress with your motor transplant?
Is the transplant recipient a 122?
Why not use the Volvo M41 transmission?
Reply #12November 26, 2008, 07:41:21 am
arb
« Reply #12 on: November 26, 2008, 07:41:21 am »
Which older models in the U.S. came with a 4-cyl.?
Andrew
The Audi 80 (type 81 body) had the 1.6L TD - http://en.wikipedia.org/wiki/Audi_80#B2_.281978.E2.80.9386.29
some guys brought them back from their military tour in Europe.
http://www.shopwiki.com/detail/d=Audi_80_%7C_1.6l_Diesel_(83-89)/
http://albany.craigslist.org/cto/911487046.html
http://nh.craigslist.org/cto/932134402.html
http://lubbock.craigslist.org/cto/927674624.html
Reply #13November 26, 2008, 08:19:56 am
arb
« Reply #13 on: November 26, 2008, 08:19:56 am »
You're saying that the Audi 80 was offered in the U.S. with a syncro tranny and a 1.6TD?
Andrew
No, here they called it a 4000 with the 5 banger... the 80's here with a 1.6L was imported by the G.I.'s ( others ?)
Reply #14November 26, 2008, 09:00:37 am
arb
« Reply #14 on: November 26, 2008, 09:00:37 am »
Right, that was my impression.  No RWD transmissions in the U.S. that will bolt up to the 4 cyl engines prior to the Quattro with the 1.8T.
Andrew
Not at all what I am saying. :-D They are here, although not in great numbers. To say they are not is like saying there are no Citroen diesel cars here from France. They are by the same path. I have laid my hands on them too here in Detroit. http://www.citroen-ca.com/members.html
Another eclectic diesel I have seen here that was not imported by the manufacturer is the diesel 2 door Mercedes-Benz Geländewagen convertible with a manual trans. http://www.gwagen.com/search.php#
