Author Topic: Possible 924 engine swap  (Read 7217 times)
June 09, 2004, 10:54:33 am
moTthediesel
  • 194
« on: June 09, 2004, 10:54:33 am »
I'm new to this list and I've got a question regarding Dub TIDI engines.
I'm looking to put together a high-economy commuter car for my wife (she puts on about 90 miles per day).
I know where I can get a nice 924 with a blown engine. As it uses a VW/Audi engine, there should be no problem bolting up a 1.6 or 1.9 IDI turbo diesel to the clutch housing, and the front motor mounts should not be too bad either. What concerns me is that the motor in the 924 is rotated 40 degrees to the left, as you look at the front of the car.
As I see it, this would rerquire a modified oil pan and oil pickup, also the drain on the turbo would need to be "clocked" around to drain down. I know that the KKK I mounted on my diesel LandCruiser could be clocked, is that true of the units used on TIDI's as well?
Can anyone think of any other potential stumbling blocks that I've missed? I think this would make a great commuter car, and should give excellent fuel economy. It's a little heavier then an A1 Volksy at 2400#, but I think that it's aero shape would more than make up for that at highway speed.
'82 LandCruiser Diesel Conversion
4Cylinder 3B/KKKturbo/AudiIntercooler(gone, BNF)
'92 Dodge/Cummins D350 Getrag Dually
356 w/Quantum 1.6TD (73 mpg!)
'85 BMW 524td (Der Komisar)
'00 Jetta TDI 5spd
Reply #1June 09, 2004, 11:18:17 am
VWRacer
  • 649
« Reply #1 on: June 09, 2004, 11:18:17 am »
The TD engine from an Audi 4000 or a VW Quantum is canted the same way. I'll check later to see if it is exactly the same angle and let you know.
Stan
Stan
C-Sports Racer
Reply #2June 09, 2004, 09:05:00 pm
moTthediesel
  • 194
« Reply #2 on: June 09, 2004, 09:05:00 pm »
Thanks guys, that's helpful!
Were the Audi 4000 and Quantum engines 1.6 or 1.9 displacement?
'00 Jetta TDI 5spd
Reply #3June 09, 2004, 09:28:18 pm
VWRacer
  • 649
« Reply #3 on: June 09, 2004, 09:28:18 pm »
My Quantum has the 1.6TD.
Stan
C-Sports Racer
Reply #4June 10, 2004, 10:55:24 am
Turbo DS
  • 54
« Reply #4 on: June 10, 2004, 10:55:24 am »
So the torque tube housing bolt pattern on a 924 is the same as an audi 5 cylinder?
Reply #5June 11, 2004, 09:38:50 pm
moTthediesel
  • 194
« Reply #5 on: June 11, 2004, 09:38:50 pm »
Yeah, the clutch housing will bolt up to any W.C. Volks/Audi engine.
If you check the 924 sites, you'll find that they try all kinds of swaps to get more power in those cars.
I'm hoping for a swap to give less! :lol:
'00 Jetta TDI 5spd
