Author Topic: 1.6td 170hp 290nm powered by holset :)  (Read 26548 times)
October 29, 2008, 03:03:47 am
zaprzal
  • 160
    • turbodiesel.pl
« on: October 29, 2008, 03:03:47 am »
special thanks:
MJF, Andy2, DVST8R, 935racer
1.6td SB engine
11mm pump
Holset hx27w turbocharger, 8.5cm2 exhaust housing
stock worn nozzles  :lol:
a bit of porting
VW T5 (thick) FMIC
2,2" freeflow exhaust
170hp 290nm  (at crank)
golf mk2 gti edition blue chassis
http://zaprzal.info/wykresy/holset/
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #1October 29, 2008, 07:00:27 am
« Reply #1 on: October 29, 2008, 07:00:27 am »
To cool man!!!!
What did you have to do for an exhaust manifold?
Just made an adapter?
Reply #2October 29, 2008, 07:05:10 am
rallydiesel
  • 1880
« Reply #2 on: October 29, 2008, 07:05:10 am »
That's awesome. I don't know too much about getting big numbers but it is apparent to me that serious exhaust porting is KEY to running getting huge power without blowing head gaskets.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #3October 29, 2008, 07:28:14 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #3 on: October 29, 2008, 07:28:14 am »
Quote from: "zukgod1"
To cool man!!!!
yes. just adapter
Reply #4October 29, 2008, 07:45:05 am
53 willys
« Reply #4 on: October 29, 2008, 07:45:05 am »
Nice work!! looks great!....that IC is HUGE!!!
so if its 170 @crank does that mean you put the engine on a engine dyno and ran it without the trans?
Reply #5October 29, 2008, 08:55:59 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #5 on: October 29, 2008, 08:55:59 am »
Quote from: "53 willys"
no. Dyno calculate power loss at wheels, trans etc.
Reply #6October 29, 2008, 10:06:51 am
Op-Ivy
  • 513
Re: 1.6td 170hp 290nm powered by holset :)
« Reply #6 on: October 29, 2008, 10:06:51 am »
Quote from: "zaprzal"
170hp 290nm
You're kidding?  :o
Nice job! I demand more exterior pics!
Reply #7October 29, 2008, 03:43:26 pm
andy2
« Reply #7 on: October 29, 2008, 03:43:26 pm »
Well done,That turbo sure works well acording to the dyno report.What boost did it take to make that power?
Reply #8October 29, 2008, 05:34:49 pm
cyrus #1
  • 360
« Reply #8 on: October 29, 2008, 05:34:49 pm »
Very nice work!  That intercooler is pretty damn big.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #9October 29, 2008, 05:44:07 pm
bugnut
  • 89
« Reply #9 on: October 29, 2008, 05:44:07 pm »
I too would like to know what you were boosting to.  Also how were the egt's during the pull?
1980 Rabbit  1.9/1.6 franko engine.  compound built in the works
Reply #10October 29, 2008, 10:58:39 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #10 on: October 29, 2008, 10:58:39 pm »
heres an interesting one:
http://zaprzal.info/wykresy/holset/3vsk24.jpg
i too would love to knw what boost and egt's were like. :-)
'91 Golf Cabrio 1.9TD
Reply #11October 30, 2008, 12:10:21 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #11 on: October 30, 2008, 12:10:21 am »
boost ~2 bar (~ 29 psi)
Egt not connected yet, but it is lower than with my last setup k24 at 29psi, no intercooler and not much less fueling ;)
Quote from: "gldgti"
holset's dyno compared to my last k24 setup
Reply #12October 30, 2008, 04:47:31 pm
« Reply #12 on: October 30, 2008, 04:47:31 pm »
what really is interesting to me is that u still have the stock intake manifold... thats crazy.
but is it really that easy?  haha it looks like all u need is a big turbo, big exhaust,  big intercooler, and a good pump, and then you can spank 1.8ts.
Reply #13October 30, 2008, 09:09:56 pm
MJF
  • 581
« Reply #13 on: October 30, 2008, 09:09:56 pm »
Quote from: "Trev0rbr"
Yep, that's all you need  8)
How's smoking? I believe no smoke under boost?
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #14October 30, 2008, 11:10:49 pm
« Reply #14 on: October 30, 2008, 11:10:49 pm »
even though its forced air, it can still benefit from a better manifold... balancing the pressures across all 4 ports will significantly reduce the risk of blowing a head gasket
