Author Topic: See the "Jetta Nose" on the mid engine 1.6TD singl  (Read 5346 times)
October 28, 2008, 11:14:23 am
914turboford
« on: October 28, 2008, 11:14:23 am »
Here is some of the latest progress on my 1.6TD single seater.
See the whole article at
http://engineconversions.org/showthread.php?p=391&posted=1#post391
Reply #1October 28, 2008, 11:15:07 am
914turboford
« Reply #1 on: October 28, 2008, 11:15:07 am »
And a few more:
Reply #2October 28, 2008, 11:20:24 am
arb
« Reply #2 on: October 28, 2008, 11:20:24 am »
Looks very stout and crash worthy in a demolition derby. I didn't notice the "why" part... that is the design goals. Are you looking to drive in NYC or Detroit and don't want to get squished, or are you using the heavy full cage because you have it?  (Understanding fully the personal value of having something no one else has !!!)
Reply #3October 28, 2008, 11:30:25 am
914turboford
« Reply #3 on: October 28, 2008, 11:30:25 am »
Quote from: "arb"
I drive 40 miles each way to work through deer country. If I ever take one on I want it to go up and over. Also, if I ever go end over end I don't want my head to drag along the ground. And, lastly, the circle track car I cut up to make this had a nice cage and it seemed like a shame not to use it.
Reply #4October 28, 2008, 11:39:43 am
allsierra123
« Reply #4 on: October 28, 2008, 11:39:43 am »
We have tons of those here we call them sand rails though. looks great.
Reply #5October 28, 2008, 12:38:13 pm
blkboostedtruck
  • 1535
« Reply #5 on: October 28, 2008, 12:38:13 pm »
that looks funner then putting a TD in a mini van!
i would make one if i had materials laying around!
someday i'll build my typ3 with a 1.9TD motor
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #6October 28, 2008, 01:24:49 pm
« Reply #6 on: October 28, 2008, 01:24:49 pm »
You need a VW emblem on the hood..
Reply #7October 28, 2008, 02:38:20 pm
  • 3468
    • McScrubbins Body Wash
« Reply #7 on: October 28, 2008, 02:38:20 pm »
that is a SICK ride. And since we're sorta on the top of bizarre vw's as you've very elegantly shown 914turboford.
Duane, i didn't know you had a type three!
there is a yellow type 3 rusting on my street under a cloth. poor thing  :(
If anyone is interested in it i can contact the owner. It hasn't moved in the 10 years i've lived here.
I think it's a type three anyways... is this a type three?
Reply #8October 28, 2008, 04:36:31 pm
blkboostedtruck
  • 1535
« Reply #8 on: October 28, 2008, 04:36:31 pm »
Quote from: "Smokey Eddy"
yep Ed thats a typ3 that pic is a 70's fast back
i have a 66 type3 it was my first car i ever bought!
i bought it in 86 and have had it ever since!
i drove it around southern calif. when i was a kid took it surfing all the time and cruzing mulholland drive where James Dean crashed and died
so now i need to put a new motor in so since i like diesels why not!
Duane
'66 variant 1500S
Reply #9October 28, 2008, 06:41:45 pm
« Reply #9 on: October 28, 2008, 06:41:45 pm »
That's so cool :shock:
The only thing that scares me is the fuel tanks location
How long have you been working on it for?
Reply #10October 29, 2008, 07:21:26 am
914turboford
« Reply #10 on: October 29, 2008, 07:21:26 am »
Quote from: "burn_your_money"
It is coming up on a year since I started working on it. I actually began building a reverse trike with a Honda 750cc drivetrain. I decided to go with a four wheeler because I came to the conclusion that it would handle better, be safer, maybe faster, and cheaper in the long run. MC parts are pretty expensive compared to car parts. Also, being a diesel, it is still exempt from smog testing in California, as it would have been as an RT. I am not too concerned about the fuel tank sitting next to me as it will be holding diesel. I guess you can get diesel to ignite but you have to get it pretty hot, like on the exhaust, which is way behind me. But maybe I should be more concerned?
Reply #11October 29, 2008, 10:21:08 am
  • 3468
« Reply #11 on: October 29, 2008, 10:21:08 am »
diesel doesn't burn as much as it explodes. I think you can actually put out a fire with diesel fuel...   :P (that's probably not true but it is really hard to get it to burn at standard temp. & pressure)
you'd have to get it VERY  hot.
I wouldn't worry personally.
Reply #12October 29, 2008, 10:29:53 am
allsierra123
« Reply #12 on: October 29, 2008, 10:29:53 am »
Hmm I was under the impression jame dean crashed in the desert on HWY 41. Maybe im wrong though.
Reply #13October 29, 2008, 10:37:23 am
« Reply #13 on: October 29, 2008, 10:37:23 am »
all it needs is a heat source hot enough, and it'll burn burn burn!!!  but yes, it could put out small flames.  at your next bon fire try splashing some on the fire  :lol: the hot cinders will make it burn, and it will put out some SERIOUS btu's!!!  i was about 5 feet away from the fire and it was still burning my face a bit... and we only poured about 1/4 litre.  :oops:  :lol:
Reply #14October 29, 2008, 11:47:30 am
arb
« Reply #14 on: October 29, 2008, 11:47:30 am »
Quote from: "jtanguay"
I poured 3 gallons on a camp fire once - It only caused it to smoke. It did not put out the fire, nor catch fire. It was the typical camp fire that had just started a few minutes before.
