Author Topic: Main Bearing Girdle  (Read 2767 times)
October 22, 2008, 01:37:31 pm
ShoulderMan
  • 89
Main Bearing Girdle
« on: October 22, 2008, 01:37:31 pm »
Does anyone know if this will fit on the 1.6l Diesel?
www.eurospecsport.com/products/components/main-bearing-girdles.htm
Part# 049-198-601-mbg
Thanks
-Ron
Reply #1October 22, 2008, 01:48:55 pm
Main Bearing Girdle
« Reply #1 on: October 22, 2008, 01:48:55 pm »
Why?
The bottom end isnt the weak link here.
I mean it's cool and all but for $500.00 you could have ALL your internal parts paid for.
Reply #2October 22, 2008, 02:24:27 pm
ShoulderMan
  • 89
Main Bearing Girdle
« Reply #2 on: October 22, 2008, 02:24:27 pm »
Never hurts to have too much insurance.  I figure if im going to rebuild the block from top to bottom, and turbo it,  it cant hurt.
  I should beable to pick that up for about $100 less.
 What is or where is the weak link in the 1.6l?
Reply #3October 22, 2008, 02:25:07 pm
Main Bearing Girdle
« Reply #3 on: October 22, 2008, 02:25:07 pm »
yea.. unless you plan on going above 200 whp, the bottom end holds up real well.  instead buy some ARP main & rod studs for a fraction of the cost (it will reduce power robbing flex)
andy2 made a main girdle for his 1.9 beast.  if you search hard enough you can find it.  it's under his compound thread.
Reply #4October 22, 2008, 03:11:38 pm
ShoulderMan
  • 89
Main Bearing Girdle
« Reply #4 on: October 22, 2008, 03:11:38 pm »
it looks as if thoes pictures have expired.
 would have been nice to have seen.
seems the head is the weakest link.
Reply #5October 23, 2008, 10:33:30 am
arb
Main Bearing Girdle
« Reply #5 on: October 23, 2008, 10:33:30 am »
Did you notice the Eurospec Main Bearing Girdles  is for I-4 with chain driven oil pumps. Our IDI VW's are not chain driven. Are the TDI flavors ?
Reply #6October 23, 2008, 12:11:20 pm
arb
Main Bearing Girdle
« Reply #6 on: October 23, 2008, 12:11:20 pm »
Ah, I must have been up too late with the project :-D
Reply #7October 23, 2008, 01:08:23 pm
Main Bearing Girdle
« Reply #7 on: October 23, 2008, 01:08:23 pm »
aren't some of the new PD/CR engines chain driven oil pumps???  or driven off a gear of the crank?
Reply #8October 24, 2008, 01:11:16 am
MJF
  • 581
Main Bearing Girdle
« Reply #8 on: October 24, 2008, 01:11:16 am »
Later TDIs are with chain oil pumps.
My girdle
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
