Author Topic: Power Steering  (Read 11406 times)
Reply #15October 21, 2008, 08:05:50 am
Power Steering
« Reply #15 on: October 21, 2008, 08:05:50 am »
i didn't think it was possible to get the power steering belt on that tight... my tension adjustment is all rusted shut so i have to remove the whole ps pump to get the belt off  :lol:
i could send you an old water pump.  it has about 100'000km on it and looks good... its for an ALH TDI, but i believe they are all the same.  should work just fine if you want it.  can anyone confirm? i'll take pics when i get a chance.
Reply #16October 21, 2008, 10:15:47 am
danwithagolf
  • 43
Power Steering
« Reply #16 on: October 21, 2008, 10:15:47 am »
ya i have to go to pick a part once a week not for my car but for fun! lol
87 Golf n/a
Reply #17October 21, 2008, 11:10:35 am
Power Steering
« Reply #17 on: October 21, 2008, 11:10:35 am »
Quote from: "danwithagolf"
HAHAHA!!
We are a sick bunch no?
Going to the PnP for fun..
I do it as well when I can.
Reply #18October 21, 2008, 03:51:38 pm
dillenger1
  • 777
Power Steering
« Reply #18 on: October 21, 2008, 03:51:38 pm »
i love thryre commercials
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #19October 21, 2008, 03:53:48 pm
  • 3468
    • McScrubbins Body Wash
Power Steering
« Reply #19 on: October 21, 2008, 03:53:48 pm »
Quote from: "jtanguay"
WELL, what ever it is, my pump leaks at the pulley :evil: .
I pull the head today. I hope my shipment from prothe is on the way...
thanks for keeping me in good cheer guys
and jtanguay
PM SENT  :lol:  :lol:  :lol:  :D  :D  :D  :D  :!:  :!:  :!:
Reply #20October 21, 2008, 04:39:34 pm
Power Steering
« Reply #20 on: October 21, 2008, 04:39:34 pm »
on your car is the WP on the same belt as the PS?  my PS has a dedicated belt on the outside.  the other ones are the problem  :evil:  :lol:
Reply #21October 22, 2008, 01:05:10 am
  • 3468
Power Steering
« Reply #21 on: October 22, 2008, 01:05:10 am »
it shares a belt with the PS i think.
Sort of unrelated but possibly related?
When i turn full lock one way or another very loud thump can be heard from the passenger strut area before it reaches full lock...
if this happens when driving it will steer in the direction the direction i full lock'd it. if i go back the opposite way it will make a similar noise and the tracking will be corrected.
Is this related to my pwr steer issues?
It normally drives dead straight (i can terrify my friends on straight roads by staring at them with no hands on the wheel :oops:  probably shouldn't do it but we've all do it from time to time if we know the road like the back of our hand!)
Reply #22October 22, 2008, 07:37:43 am
Power Steering
« Reply #22 on: October 22, 2008, 07:37:43 am »
Well it could be rack related but I would lean towards a strut bearing first.
Can you get someone to turn the wheel so you can watch front end pcs?
Reply #23October 22, 2008, 10:21:15 am
  • 3468
Power Steering
« Reply #23 on: October 22, 2008, 10:21:15 am »
When its in the air it won't make the noise so you're right about strut bearing i think...
What should I do about it?
I've been driving it like this for ... oh ... at least a year. When it pops out i just curse silently to my self, steer the other way till it pops back and go on my way.
Reply #24October 22, 2008, 10:58:17 am
Power Steering
« Reply #24 on: October 22, 2008, 10:58:17 am »
replace it, they are CHEAP new and I'll bet from a PnP they are way cheap.
Reply #25October 22, 2008, 01:53:26 pm
Power Steering
« Reply #25 on: October 22, 2008, 01:53:26 pm »
yep sounds like the strut bearing...  worse i've had was a broken spring that made some terrible noise when turning the wheel  :shock:  :lol:
Reply #26October 22, 2008, 04:11:01 pm
  • 3468
Power Steering
« Reply #26 on: October 22, 2008, 04:11:01 pm »
uhhhh pardon my mental defficiencies, what is the strut bearing?
Reply #27October 22, 2008, 05:31:22 pm
Power Steering
« Reply #27 on: October 22, 2008, 05:31:22 pm »
Quote from: "Smokey Eddy"
it allows the strut to turn with the wheel.  its right up top where those two caps are.  when i replaced mine they were pretty bad, but still useable. felt really good when they were replaced  :wink:
edit: the strut needs to come off to replace it, and some might argue that an alignment is necessary afterwards, but you can simply scribe the position of the strut before removing it, and then re-installing it using the mark.
Reply #28October 22, 2008, 09:55:40 pm
  • 3468
Power Steering
« Reply #28 on: October 22, 2008, 09:55:40 pm »
I took the driver side strut off (the one that doesn't make the noise)
and putting it back on i just lined up the marks where the strut isn't dirty/rusted/corroded
holy was it ever difficult though... i need an impact gun
Reply #29October 23, 2008, 07:46:18 pm
Power Steering
« Reply #29 on: October 23, 2008, 07:46:18 pm »
You don't need to take the strut off the car on a mk2 or a mk3. Not sure about other years. Just jack the car up, loosen off the upper strut mount, force the wheel down and you will be able to finagle the old strut bearing out and the new one in. Just watch your fingers
